Results 1 to 3 of 3
    ROG Member Array DarkShadow PC Specs
    DarkShadow PC Specs
    MotherboardAsus ROG Strix X570 F Gaming
    ProcessorAMD Ryzen 5 3600
    Memory (part number)G. Skill Trident Z RGB 3200 Mhz
    Graphics Card #1Asus GTX 1080 Turbo
    MonitorAsus VG248Q
    Storage #1Samsung Evo Plus 512GB m.2 NVMe SSD
    Storage #2Western Digital 3TB HDD
    CPU CoolerNZXT Kraken X72 360 Liquid Cooler
    CaseTharmaltake View 71 TG RGB
    Power SupplyAntec High Current Gamer 750W Full Moduler
    Keyboard Corsair K91 RGB Platinum Mechanical kEYBOARD
    Mouse MSI DSB1 Gaming Mouse
    Headset Phantake G11
    Mouse Pad Corsair MM800 Polarise RGB
    Headset/Speakers Microlab 2.1
    OS Windows 10 Pro
    Jun 2018
    6
    ASUS ROG Ryujin 360 CPU Cooler Temperature Issue
    Recently I just upgraded to ASUS ROG Ryujin 360 CPU Cooler. I am using Asus ROG Maximus X Hero with Intel Core i7 8700K. After installing the cooler perfectly, the stock CPU temperature shows 40 - 42 degree C without overclocking. But as I seen some reviews online/Youtube with the same Motherboard & CPU, temperature should be 25 - 30 degree C Beside I installed 2500 RPM Fan both side of the Radiator for push & pull airflow. I did not use any other thermal paste as ASUS ROG Ryujin 360 came with pre installed thermal paste.
    I am realy confused !!! Need Help from Experts.
    ROG Guru: Orange Belt Array ninezerofive PC Specs
    Laptop (Model)Laptop ? Ewww
    MotherboardMaximus XI Apex
    Processori7-9700K @ 5.2
    Memory (part number)Trident Z Royal 4000 / 2x8GB @ C17
    Graphics Card #1ROG Strix 1070 OC
    Storage #1Corsair MP510 960 GB
    Storage #2Seagate 3TB
    CPU CoolerROG Ryuo 240
    CaseROG Helios
    Power SupplyROG THOR 850W
    Keyboard ROG Claymore
    Mouse ROG Pugio
    Headset ROG Cerberus
    Mouse Pad ROG Whetstone
    Accessory #1 ROG Terminal
    ninezerofive's Avatar
    Nov 2018
    18
    262
    In my experience it's not the thermal paste. I did the test with Ryuo 240 and Arctic MX-4 did the same as pre-applied ASUS one.
    Edit : temperature alone doesn't mean anything, maybe they done tests in Norway in cold room, while you sipping margaritas on the beach trying to stress test your PC in the sun
    ROG Guru: Orange Belt Array 1mluer PC Specs
    1mluer PC Specs
    MotherboardMaximus XII Apex
    ProcessorI9-10900k
    Memory (part number)Gskill Trident Royal 4400
    Graphics Card #1ROG Matrix 2080 ti
    Sound Cardbuilt in
    MonitorASUS Swift PG348Q
    Storage #1Samsung 970 EVO Plus Raid
    Storage #2Samsung 970 EVO Plus Raid
    CPU CoolerRyujin 360
    CaseInWin 909 Silver
    Power SupplyROG Thor 1200p
    Keyboard ASUS ROG Claymore
    Mouse Logitech G900
    Mouse Pad ASUS ROG Baltheus
    Headset/Speakers Bose Computer Set with Sub
    OS Windows 10 Pro
    Network RouterNightHawk RAX200
    Accessory #1 TT Riing Plus
    Accessory #2 Blue Microphone
    Feb 2017
    42
    421
    Quote Originally Posted by DarkShadow View Post
    2 things come to mind:
    Is the cooling block flat against the CPU as in did you try to apply equal pressure on the standoffs as you tightened it down. also check your standoffs to make sure they are fully extened and flat against the motherboard. My brother didn't realize he had a standoff not seated correctly with the back plate. maximum contact with IHS on the CPU is critical to even heat displacement.
    and
    What version of livedash are you using. I would use the version recommended for your motherboard in the support section. Is the ambient temps average to low in your home?
    All I can think of at the moment.
    InWin 909 Silver RGB build
    i9-10900k
    ROG Maximus XII Apex
    ROG Matrix 2080 ti
    Gskill Trident Royal 4400 16g
    Everything overclocked and love it.
    ROG Awesomeness !!!!
Tags for this Thread
