Results 1 to 10 of 10
    ROG Member Array
    Jun 2018
    6
    ASUS ROG Ryujin 360 CPU Cooler Unusual Temperature
    Recently I just upgraded to ASUS ROG Ryujin 360 CPU Cooler. I am using Asus ROG Maximus X Hero with Intel Core i7 8700K. After installing the cooler perfectly, the stock CPU temperature shows 40 - 42 degree C without overclocking. But as I seen some reviews online/Youtube with the same Motherboard & CPU, temperature should be 25 - 30 degree C Beside I installed 2500 RPM Fan both side of the Radiator for push & pull airflow. I did not use any other thermal paste as ASUS ROG Ryujin 360 came with pre installed thermal paste.
    Previously I used Corsair H100i GTX 240. In stock ideal temperature was 46 - 48 degree C. Then whats the point to upgrading 240 to 360 Cooler !!
    I am really confused !!! Need Help from Experts.
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    13
    1,500
    I am reading you post. You are right. MOST reviewers have ambient temps on the 20-24C. You can not go below ambient temp. on normal ways.
    If you have 40-42c with no oc, your ambient temps are between 35to37C. In my case, in idle my temps are 38C with 1000rpm fans. so should bo now on 30ish 31C.
    Check, using hwinfo64 what are the temps there.
    Learn, Play Enjoy!
    ROG Member Array S4lticid PC Specs
    S4lticid PC Specs
    Laptop (Model)Alienware m17x R3 (old machine, still in use)
    MotherboardASUS ROG Maximus XI Hero w/ Wifi
    Processori9 9900K
    Memory (part number)G.Skill Trident Z 32 Gb DDR4-3600 cl 14
    Graphics Card #1EVGA 2080 TI FTW3
    Sound CardSound Blaster X Katana w/ subwoofer
    Monitor1) ACER Predator Z1 | 2) Samsung 32" curved gaming
    Storage #11) Samsung - 970 Evo Plus 250 GB M.2-2280 | 2) Samsung - 860 Evo 1 TB 2.5"
    Storage #23) Seagate Barracuda 2 TB 7200 RPM | 4) Crucial MX500 500 GB SSD
    CPU CoolerCustom Loop, EK Supremacy EVO CPU block, EVGA Hydrocopper GPU block, EK Coolstream XE 360 X2
    CaseThermaltake View 71 TG
    Power SupplyEVGA SuperNOVA P2 1200w 80+ Platinum
    Keyboard ROG Strix Flare
    Mouse Trackball
    Headset HyperX Cloud II
    Headset/Speakers Sound Blaster X Katana w/ subwoofer
    OS Windows 10 Pro
    S4lticid's Avatar
    Apr 2019
    36
    22
    I've never used an AIO, only custom loops, but a few thoughts:
    Never use stock TIM. Especially pre-applied to a new cooler you're supposed to install yourself. My only exceptions are thermal pads on appropriate components unless temps indicate they need replacement, and if 'stock' means the manufacturer gave me a separate package of paste to apply myself and I know it's a good brand. I even open new pre-built machines and re-paste CPUs and GPUs, and I always see an improvement.
    A push-pull configuration on that rad is completely unnecessary overkill and unless your fans are matched and you're sure they're synced on each side of the rad, it's possible you could be causing more problems than helping. Get rid of a set of fans and see if it helps.
    As already mentioned, you can't expect to necessarily reach the temps on those reviews as your own local conditions may be different. What is the ambient temperature in the room you're in? The temperatures you can reach are going to be limited by this.
    MrAgapiGC PC Specs
    Processor9900K
    CaseNzxt H700
    Mouse Asus Spartha
    MrAgapiGC's Avatar
    Nov 2011
    13
    1,500
    Quote Originally Posted by S4lticid View Post
    correct, but the asus aio comes with noctua thermalpaste, i can confirm that. i am saving to get one. since i all ready test a loop, basic and is the same at 3000rpm. pump speed. I think I will get another loop for my cpu soon. i want complete control bit the bios these time.
    Learn, Play Enjoy!
    S4lticid PC Specs
    Processori9 9900K
    Mouse Trackball
    OS Windows 10 Pro
    S4lticid's Avatar
    Apr 2019
    36
    22
    Quote Originally Posted by Itzycharles View Post
    Noctua, eh? It still tweaks my OCD that they would pre-apply it... but that is a good paste. =)
    I'd still change it for Kryonaut tho. OCD.
    Still wouldn't run a push-pull on a 360 rad that's only cooling a single component, not even OC'd. Especially not when the fans that come with it are daisy chained to be controlled together, but the other side would have to be added by the user and synced to the others manually.
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    79
    912
    Quote Originally Posted by DarkShadow View Post
    I wouldn't bother with the extra set of fans in push pull. Unless fans are matched it can actually hurt performance. The Noctua fans on the Ryujin are excellent as they are.
    Verify your fan and pump speeds in Fan Expert. Make sure your pump is running no less than 60% at idle and ramping up from there. Some users run it at 100% full time.
    The main advantage of a 360 rad versus say a 280 rad is quietness. But it should out perform a 240 rad.
  7. #7
    ROG Member Array
    Jun 2018
    6
    In my 360 Rad, one side i used 2500 RPM Corsair LED fans, onthe other side of Rad i used Rog Ryujin's 2000 RPM Noc Fans. Corsair is pushing & ROG is pulling. That means pushing 2500 RPM & Pulling 2000 RPM. Is that OK?
  8. #8
    ROG Member Array
    Jun 2018
    6
    That does that mean !!
  9. #9
    S4lticid PC Specs
    Processori9 9900K
    Mouse Trackball
    OS Windows 10 Pro
    S4lticid's Avatar
    Apr 2019
    36
    22
    It means that unless the room you're in is 38 degrees Celcius (100+ Fahrenheit) or hotter, your temps are too high for someone using an AIO cooler at stock volts and clocks.
    You should not be running a push-pull on that rad, especially not with different fans than came with the kit.
    Different RPMs and pressure, not synced to work together, no this is not good and can cause problems.
    The kit came with everything it needed. Use only what came with it and you will be fine.
    Take the extra fans that did not come with the kit off, and try again.
    The temperature of the room you're in will change your results from the reviews you've seen, but it shouldn't by that much unless you live somewhere really hot. Do you?
  10. #10
    ROG Member Array
    Jun 2018
    6
    For experiment I completely removed all 3 fan from one side of Rad. Remains only one side 3 fans 2500 RPM
    But unfortunately same result !! I hardly notice any difference !! That means, both side of fan in Rad is not the issue so far.
    Then whats the issue !! Average temp of my room may b 25 - 30 Degrees.
    I should mention my setup:
    Intel Core i7 8700K
    Asus GTX 1080 Turbo
    G. Skill Trident Z RGB 3200 mhz
    Asus ROG Ryujin 360
    Asus ROG Thor 850W
    WD HDD Purple 3TB + Intel Optain memory module 32GB
    WD HDD Blue 1TB
Tags for this Thread
