04-16-2019 01:53 AM - last edited on 03-06-2024 08:23 PM by ROGBot
04-16-2019 02:07 AM
04-16-2019 04:11 AM
ninezerofive wrote:
I don't think Hero can run "Gskill 2x8 4400 MHz". Gene can hardly run it. Set the DRAM manually to 4000 and see if that helps. If it does, then you can try to increase it until the point where HERO gives up.
04-16-2019 04:22 AM
04-16-2019 05:56 AM
ninezerofive wrote:
There generally used to be a problem with first batch of RTX cards, where some of them artifacted and some of them straight up crashed during any kind of load. So it might be GPU as well. For starters I would advise to run GPU Tweak II and set on screen display for CPU and GPU and then go ahead and play the BF5, see what kind of temperatures are they reaching. And does it only happen when it reaches that specific temperature.
If it crashes at like GPU 78C, then in GPU tweak set the max temp to 75C and play for couple hours. If it's stable, then it's GPU.
04-16-2019 05:41 PM
Colorist wrote:
That could be true. I've had the same problem in heaven benchmark stress test. And temperature was like 78C as you said. I'll answer back after try this.
04-18-2019 01:58 AM
ASchiavi wrote:
Remove the VGA try onboard video and run prime95, easiest way to discard GPU
04-18-2019 01:48 AM
04-16-2019 11:01 PM
