Results 1 to 3 of 3
    ROG Guru: White Belt Array
    Jan 2013
    12
    91
    Mounting VI Omega in case
    Hi Guys,
    so all large Motherboards are usually mounted to the case via 3 screws. The 9th in this case been the TOP Middle is not accessible.
    Has anyone secured the motherboard at this point and how?
    MB: ASUS Rampage V Extreme
    CPU: Intel Core i7 5960X Extreme Edition
    RAM: Dominator® Platinum Series 32GB (4 x 8GB) DDR4 DRAM 2800MHz
    PSU: Corsair AX1200i Digital ATX Modular
    GFX: 3 x EVGA GTX Titan Black Superclocked 6GB
    SSD: 2 x Samsung 850 Pro Series 512Gb SSD Raid 0
    HDD: 2 x WD4003FZEX WD Black 4TB Raid 0
    1234;
    2 x WD1000DHTZ WD VelociRaptor 1TB Raid 0
    MON: Dell Ultra Sharp 32 Ultra HD Monitor - UP3214Q
    CASE: Silverstone Temjin TJ11 Black with Window Case
    OS: Win7 x64bit
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus R6EO Bios 0702
    Processori9 9900X @ 4.9 1.28V VCore
    Memory (part number)GSkill F4-3600C16Q2-64GTZR
    Graphics Card #1EVGA 2080 Ti Kingpin
    Sound CardCreative SB AE7
    MonitorAsus ROG PG349Q
    Storage #1Intel 905p M.2 360G
    CPU CoolerEKWB Velocity RGB and Revo XRes 140 D5
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Asus Strix Flare
    Mouse Asus ROG Gladius II Origin
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    36
    2,063
    I didn't. I couldn't figure out how to do that, so I just did not use that screw. I think mine is fine with the other 8.
    ROG Guru: Yellow Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Keyboard Logitech G910
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    12
    246
    Your manual shows mounting it with only 8 screws. You ought to read it sometime.
