Results 1 to 7 of 7
    New ROGer Array Mod83's Avatar
    Apr 2019
    6
    Sponsored - Phantom Gaming Build
    Mod83 are delighted to annouce a new build featuring the ASRock Phantom Gaming Alliance in association with Cooler Master and TeamGroup.
    The new build will be based on the AMD Threadripper platform using the ASRock X399 Phantom Gaming 6 motherboard, a feature filled premium ATX board designed for gaming.
    The motherboard will be paired with components from Team Group, notably XCalibur Phantom Gaming RGB (4x8gb) DDR4 3200 and the T-Force Delta Phantom Gaming RGB 256Gb SSD.
    The build will then be completed with hardware from Cooler Master including the H500P and Wraith Ripper cooling solution.
    We will of course bring you all the build updates as they happen and component reviews along the way. Stay tuned for updates as we begin this new build!
    See more at www.mod83.com
    Apr 2019
    6
    We have now taken delivery of most of the components we will be needing for this build, we are still waiting on a few but we have enough to get started. The specs for this build will be;
    AMD Threadripper 1950X
    X399 Phantom Gaming 6 Motherboard
    TeamGroup Excalibur 32Gb DDR4 3200
    ASUS Strix GTX 1070
    TeamGroup Delta 256SSD
    Cooler Master 750W PSU
    Cooler Master H500P
    Cooler Master Wraith Ripper
    Cooler Master MF120 Case Fans
    We will of course take a look at all the hardware in a little more depth with our reviews coming during the build. For now we will be starting with getting the motherboard and additional components in place so that I can start looking at taking measurements for some custom trim work both internal and external.
    Our thanks once again to ASRock, TeamGroup and Cooler Master for making this build possible and dont forget you can check out all our latest build info at www.mod83.com
    Apr 2019
    6
    Quote Originally Posted by DJEmir View Post
    Can't wait to see what this beast looks like, I really like the Dominus Build you guys made at
    https://rog.asus.com/articles/gaming...intel-28-core/
    made my mouth water LOL and made me want to start my next build
    Hi and thanks for the reply. Not sure on the Dominus build, we didnt do that but we did do Project Octane recently.
    The build log for that can be found here: https://rog.asus.com/forum/showthrea...Project-Octane
    ROG Guru: Green Belt Array drop4205 PC Specs
    drop4205 PC Specs
    Laptop (Model)What are laptops
    MotherboardMaximus XI Formula
    ProcessorI9-9900K
    Memory (part number)Gskill Trident Z F4-3200C14-32GYZR
    Graphics Card #1Nvidia Reference RTX2080TI
    Graphics Card #2ha I wish
    Graphics Card #3ha I wish
    Graphics Card #4ha I wish
    Sound Cardha I wish
    MonitorAsus VN247H-P 23.6"
    Storage #1Samsung970 EVO Plus 1T
    CPU CoolerHeatkiller
    CasePhantex Evolove X
    Power SupplySessonic Prime Titanium 850
    Keyboard ROG Strix Flare
    Mouse ROG Gladius II
    Headset Astro A40
    Mouse Pad Corsair
    OS Windows 10 Home 64 Bit
    Accessory #1 Ek GPU Block
    Accessory #2 EK SE 360 Rad, EK PE 360 Rad
    Accessory #3 EK D5 Vario 140 Pump/Res
    drop4205's Avatar
    Mar 2013
    21
    502
    looking good
    Maximus XI Formula, I9-9900k, Phantex Evolove X, Seasonic Titanium 850W, Custom loop PE360+SE360 Rad, G.Skill Trident Z F4-3200C14 32g, Nvidia Reference RTX 2080 TI, Samsung 970 EVO Plus 1Tb, ROG Strix Flare keyboard, ROG Gladius II
    Apr 2019
    6
    Our Phantom Gaming build is now underway with the first parts being installed. The H500P has bee stripped of its PSU basement shrouds ready for replacements to be fabricated giving us easy access to start fitting components.
    So far we have installed the Cooler Master MF120mm fans, V750 PSU and Phantom Gaming 6 motherboard from ASRock.
Name:	H500P Top Fans.jpg
Name:	H500P Front.jpg
Name:	V750 PSU Fitted.jpg
Name:	PG6 Installed.jpg
    The most exciting part today though is the CPU, AMD were kind enough to send over their flagship 2990WX instead of a 1950X for this build. This is a monster of a CPU and given its our first experience with Threadripper we are really excited to see how it performs. This rig will be used for upcoming builds as a video editing workstation so we have all the grunt we need for footage.
Name:	2990WX Boxed.jpg
    So the hardware is coming along nicely so far but then we hit a snag. Due to the height of the TeamGroup Phantom Gaming DDR4 we are using the Wraith Ripper is about 3mm short of clearance and cannot be used. We are on with arranging an alternative cooler so we will bring more on that in our next update.
    Apr 2019
    6
    Now that the AMD Threadripper 2990WX is installed we can get our RAM fitted. The RAM we are using for this build is kindly supplied by TeamGroup and features 4x8gb DDR4 3200 Excalibur Phantom Gaming modules.
    This high performance quad channel kits takes up 4 of the 8 DIMM slots on our motherboard, leaving it open for us to increase capacity to 64gb at a later date if needed. THE RGB headers should look amazing on this build and we cant wait to light it up.
    After the issues we had with the Wraith Ripper, Cooler Master have kindly sent over a ML360 TR4 Edition as a replacement. We were really hoping to use the Wraith Ripper for this build, its a fantastic looking piece of kit but we overloooked the RAM height and hopefully we can feature one in a future build.
    A 360mm radiator should offer plenty of cooling for our CPU, its changed some aspects of our design plan but I am sure we can come up with something as an alternative. It also adds another 3 RGB 120mm fans to the build for the front panel.
    Part 5 of this build log will move to the assembly and fabrication of our new basement shroud, we shared imagess of that via our Facbook Page and it was really well recieved. Stick around and see you for the next chapter.
  7. #7
    Apr 2019
    6
    Not the biggest update but it brings our Phantom Gaming build on leaps and bounds in terms of aesthetics. Our new basement shroud is now bent to shape, sprayed and ready for install. Made from a single sheet of 3mm A3 acrylic, its a perfect fit in the H500P.
Name:	Shroud unpainted.jpg
Name:	Shroud INstall.jpg
    Once we have it installed we will need to add a strip of sanded acrylic behind the shroud to allow the RGB LEDs to shine through evenly, spreading the light across the ful logo
    The colour match is almost perfect, we are using Rust-Oleum Gun Metal rattel cans for this project after using their products for our Rocket League build.
    Another part completed this week is our top fan cover. This has both Team Group and Phantom Gaming logos applied and agian finieshed with Rust-Oleum Gun metal. The only difference between the two parts is the top cover was sprayed internally and still has the protective plastic cover on.
Name:	Top Cover.jpg
    Now we have these installed we can move back to hardware and fit our ML360 RGB TR4 AIO from Cooler Master and other hardware in Part 6.
