Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    ROG Guru: Orange Belt Array Psycrow PC Specs
    Psycrow PC Specs
    MotherboardMaximus Extreme XIII
    Processor11900k rocket lake
    Memory (part number)32 GB G skill Trident Z royale
    Graphics Card #13080 to auros master extreme OC
    Storage #1M.2 Samsung 980 1 tb
    Storage #2M.2 Samsung 980 1 tb
    CPU CoolerNH-U12A
    CaseMeshify 2 XL
    Power SupplySeasonic 1300w Prime
    Keyboard G 815 Tactile
    Mouse Roccat pro kone
    Mouse Pad Steelserie Prism 5XL
    Psycrow's Avatar
    Apr 2013
    33
    341
    Asus aura ( Oh no !)
    I just installed asus aura again since i want to see if things has changed since last time.
    But sometimes the program dosent even load or it gives me the " program has stopped responding" error.
    Then i reinstalled it over and over until it finaly worked. Now when i open the program, then i only see
    my G skill ramm that can be linked in order to work with the program. And i did that.
    I could controle my ram RGB but there was no motherboard option to see.
    Im using Formula IX ROG and it comes with some rgb ligths that are set to rainbow mode for defaults.
    I could not set the motherboard to any mode since there was no option for it...
    What is wrong here ?
    Program dosent want to work allways and when it works, there i sno motherboard option.
    I had installed it for a year ago and there i could see my ram and motherboard an di could link both..
    Did Rgb go down the drain that badly ?
    I tryed to install G skill aura an dit was the same program same problems. Then i tryed G skill royale and it worked fine ONLY with my ramm.
    So how do i control emy motherboards rgb beside turning em on and off in bios ?
    ROG Guru: Orange Belt Array 1mluer PC Specs
    1mluer PC Specs
    MotherboardMaximus XII Apex
    ProcessorI9-10900k
    Memory (part number)Gskill Trident Royal 4400
    Graphics Card #1ROG Matrix 2080 ti
    Sound Cardbuilt in
    MonitorASUS Swift PG348Q
    Storage #1Samsung 970 EVO Plus Raid
    Storage #2Samsung 970 EVO Plus Raid
    CPU CoolerRyujin 360
    CaseInWin 909 Silver
    Power SupplyROG Thor 1200p
    Keyboard ASUS ROG Claymore
    Mouse Logitech G900
    Mouse Pad ASUS ROG Baltheus
    Headset/Speakers Bose Computer Set with Sub
    OS Windows 10 Pro
    Network RouterNightHawk RAX200
    Accessory #1 TT Riing Plus
    Accessory #2 Blue Microphone
    Feb 2017
    42
    421
    Quote Originally Posted by Psycrow View Post
    I would suggest installing the version that is recommended for your motherboard. go to the support area for your motherboard and use that one. My aura didn't work until I used the one suggested for my motherboard and not the latest one.
    go to the support section of the main site.. look up your motherboard then go to utilities and click show all .. it should be listed there. I too also had at Maximus IX version.. Apex.
    I would completely uninstall the version you have now.. Reboot the machine before installing the version listed for your motherboard.
    InWin 909 Silver RGB build
    i9-10900k
    ROG Maximus XII Apex
    ROG Matrix 2080 ti
    Gskill Trident Royal 4400 16g
    Everything overclocked and love it.
    ROG Awesomeness !!!!
    Psycrow PC Specs
    CPU CoolerNH-U12A
    CaseMeshify 2 XL
    Psycrow's Avatar
    Apr 2013
    33
    341
    Quote Originally Posted by 1mluer View Post
    I tryed what you suggested, t least the program is working now and i can use it, But i dont see my motherboard anywhere in the top
    This is what i see. Would a bios reset work ?
    1mluer PC Specs
    ProcessorI9-10900k
    Sound Cardbuilt in
    Mouse Logitech G900
    OS Windows 10 Pro
    Feb 2017
    42
    421
    YES It would probably work like it did for me.. go to the following sections in bios.
    go into bios: > Go to Advanced > Go down the Onboard Devices Configuration > Go down to the RGB LED lighting and turn it off..
    I would save and reboot. I would then go back into bios and go back to that setting and turn it back ON. > Save and reboot again and check it. It should work hopefully for you as it did for me.
    i9-10900k
    ROG Matrix 2080 ti
    1mluer PC Specs
    ProcessorI9-10900k
    Sound Cardbuilt in
    Mouse Logitech G900
    OS Windows 10 Pro
    Feb 2017
    42
    421
    Did it work ?
    i9-10900k
    ROG Matrix 2080 ti
    Psycrow PC Specs
    CPU CoolerNH-U12A
    CaseMeshify 2 XL
    Psycrow's Avatar
    Apr 2013
    33
    341
    Sorry i forgot about it all here in the easter hollidays..i will do it tomorrow when i wake up but it sounds like it could work
  7. #7
    Psycrow PC Specs
    CPU CoolerNH-U12A
    CaseMeshify 2 XL
    Psycrow's Avatar
    Apr 2013
    33
    341
    It disent work..my motherboard wont show up in that program at all..only my ramm shows up and they are not even asus brand
  8. #8
    1mluer PC Specs
    ProcessorI9-10900k
    Sound Cardbuilt in
    Mouse Logitech G900
    OS Windows 10 Pro
    Feb 2017
    42
    421
    Change version of aura sync. I had to do that to get it to work too. It's got to be one of those two.
    i9-10900k
    ROG Matrix 2080 ti
  9. #9
    ROG Enthusiast Array DMAN999 PC Specs
    DMAN999 PC Specs
    MotherboardROG Strix X470-F Gaming
    ProcessorAMD Ryzen 7 3700x
    Memory (part number)G.Skill Ripjaws V 16GB (F4-3600C16D-16GVKC) @ 3733 MHz
    Graphics Card #1MSI RTX 2060 Super Armor OC
    MonitorDell S2316M
    Storage #1Samsung 850 Evo 500 GB SSD
    Storage #2Crucial MX500 nvme m.2 SSD
    CPU CoolerArtic 33 Esports Edition
    CaseRosewill Challenger
    Power SupplyRosewill Photon 750
    Keyboard Cooler Master MK120 RGB
    Mouse Cooler Master MS120 RGB
    Mouse Pad SteelSeries QcK Gaming Surface
    OS Windows 10 x64
    DMAN999's Avatar
    Dec 2018
    12
    62
    I would Unistall Aura then run a registry cleaner (like CCleaner).
    Then reboot and try installing Aura again.
  10. #10
    Psycrow PC Specs
    CPU CoolerNH-U12A
    CaseMeshify 2 XL
    Psycrow's Avatar
    Apr 2013
    33
    341
    Quote Originally Posted by DMAN999 View Post
    Been there done that..dident work
