Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    ROG Member Array
    Feb 2012
    5
    G53 Screen Problem
    Hello, a month ago I bought an g53 laptop from tiger direct, everything worked great until yesterday when my screen refused to show anything after standby, after a few reboots the screen went fine and all was working perfect, I played fifa 12 and no problems at all, so I suspend it again, and today when I wanted to use it again the screen refused to show anything, and now I dont know how to solve it.
    It seems like it starts as I hear the windows chime, also pluging to hdmi or vga does nothing, tried the fn combinations with no result.
    Im from Argentina and the Asus service says that it only gives supports to laptops bought here (argentina).
    also I tried removing one ram, the easiest to take off and the problem persists, I see no post, or nothing, its like the screen is off.
    Please help me as I have been reading for a while and seen other g53 owners with the same problem, but nothing is said about how to solve it.
    thanks in advance.
    ROG Enthusiast Array
    Sep 2011
    27
    Its likely your graphics card. Did you see any artifacts ant any times (especially in games)? Any GSOD? Were you/ have you been monitoring temps? If so what is the highest you have ever seen your graphics card and what did it idle at? It COULD be the cable from your graphics card to your panel, i doubt it though.
    Ultimately its gonna require an RMA unless you feel like fixing it yourself.
    Just to confirm. I am under the impression that you CANT see the asus logo before windows starts loading, is this correct?
    EDIT: Artifacts are little speckles or lines or flashes on the screen that aren't meant to be there.
    ROG Member Array
    Feb 2012
    22
    Hello, read my post #5, http://rog.asus.com/forum/showthread...SX-RH71-Anyone as far as what Asus told me. Then check out my last post on page 2 #11 if your interested in opening up the lappie to check more connections. I am guessing the video card might be in the area I described. Try to restart lappie by holding it level in the air from the right front corner allowing the weight overhang in your hand. I know how ridiculous this sounds but it works for me til I can get a spare lappie to return this one. Seems like putting pressure on the bottom of that area is reconnecting what is loose or worse....cracked. And please4 post your results!
    BTW... Resetting the mobo 2-3 times did not help me but i would try my last suggestion before doing so
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    89
    4,437
    Quote Originally Posted by fedex-bermu View Post
    If an external monitor fails to display an image, it could indicate a problem with the GPU. Are you sure you configured the external monitor to use HDMI or VGA input? However, since you did not report any artifacts or other video corruption, it is possible you may be experiencing a different problem.
    1) Did you try the Fn-F7 key combination that turns the laptop display on and off? Even if the laptop display was turned off with this key combo, the external monitor should still display video.
    2) If you already tried Fn-F7, do the recommendations in http://windows.microsoft.com/en-US/w...tart-windows-7 change behavior?
    3) Reseating the HDD(s) as well as RAM has sometimes resolved this issue.
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
    ROG Member Array
    Feb 2012
    5
    Today when I turned on the laptop it just worked, I moved the screen a little bit on the sides and it appeared the asus logo, now Im writing from my laptop.
    Im still worried what can it be...
    I tried yesterday pressing the fn + f7 and f8, also the brightness with no result, there was no signal through hdmi or vga. Today that its working fine hdmi works great.
    Also, no artifacts, I play great with ultra settings.
    New ROGer Array
    Feb 2012
    4
    I'm currently having this same problem as well. At vudugans suggestion holding the laptop as he said does seem to work to get it to turn on. Also, when its on everything works great no artifacts, games run on max settings etc. but as soon as I shut down it will not turn on again unless properly fondling the laptop. One of the certified repair places is not too far from me I might go there before I decide to RMA it. I will post information as I find it out as this does not seem to be isolated and is becoming more common lately.
  7. #7
    Sep 2011
    89
    4,437
    Check out this thread: http://forum.notebookreview.com/asus...sus-g53sx.html It maybe worthwhile to PM Chastity at the Notebook Review Forums and hopefully get a case number. Physically manipulating the laptop to get the screen to work most likely indicates a hardware issue requiring repair work.
  8. #8
    ROG Member Array
    Feb 2012
    5
    In asus page it says that the laptop has a 2 year global limited warranty, and in the sicker under my laptop says 12m <ga> so... its 2 years or 1? its global or local?? Im confused
    Also, as I live in Argentina, and I bought the laptop in USA, Asus refuses to repair my laptop under the warranty, what should I do? any advice would be greatly apreciated.
    Should I buy the global extension so Asus recognises the warrantyin my country? Im a little pissed off as its not clear what type of warranty do I have...
  9. #9
    Sep 2011
    89
    4,437
    I agree that ASUS Warranty information is very unclear. If you login to https://vip.asus.com/login.aspx with the email address and password you created to register your notebook online, you can view your registered ASUS products on the resulting "Member" screen. If you click on the "Warranty Info" link on that page, you are directed to http://support.asus.com/Repair.aspx?SLanguage=en where it states:
    1 Check Warranty Card
    Check your warranty card content to confirm the warranty term and warranty period. (If you do not have them beside you, we will use the ASUS product’s original shipping date as your purchase date).
    Quite frustrating... I recommend PMing Mason@ASUS on this forum to help you sort it out.
  10. #10
    Sep 2011
    89
    4,437
    Just curious... For those of you that must physically manipulate your notebook to get the display to work, does the following procedure allow a successful start after getting a blank screen:
    Unplug your notebook and remove any attached peripherals (power adapter, mouse, USB drives, external monitors, etc.), remove the battery, press the power on button and hold it down for 30 seconds, attach the power adapter, plug in and boot.
