Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
    ROG Enthusiast Array ayman_abm PC Specs
    ayman_abm PC Specs
    MotherboardRampage VI Extreme
    ProcessorIntel i9-9980XE
    Memory (part number)CMD32GX4M2C3200C16
    Graphics Card #1ASUS GeForce GTX 1080 Ti
    CPU CoolerEKWB EK-FB ASUS ROG R6E RGB MONOBLO
    CaseCoolerMaster cosmos c700p
    Power SupplyThermaltake Toughpower Grand RGB 1200W 80+ Platinum Smart Zero RGB
    OS Windows 10 Pro
    Sep 2012
    32
    Angry R6E + 9980XE code 00
    Dears,
    I have R6E since October 2018 and never unboxed it or used it, I bought it and waited for the i9 9th Gen CPUz. Several Days ago I bought the 9980XE from Amazon, Installed it, and got CPU Code:00, so I thought its a BIOS issue, Since I have the board long Time ago and never used it before.
    what Steps I did:
    • Downloaded The BIOS from ASUS website 1704 and renamed the file to R6E.CAP
    • Installed That BIOS using Flash Back
    These Steps didn't help and still getting CODE 00. I found also in ASUS Site that BIOS 1603 Supports 9980XE, so I found that BIOS Online, and Flashed it to the 2nd BIOS, also didn't HELP.
    I went to a computer shop where I bought This Board, and we used an OLD CPU Gen (7900x) and the board Booted Success, we Flashed again Both BIOSs using Flash Back from BIOS Settings (F2) and tried the 9980XE but same error code 00 appears.
    We changed the VGA Card twice and also PSU , that didn't help.
    Last thing we did, we tried this CPU on other Boards (Strix-E and Tuff) and these boards also couldn't start with this CPU.
    Note: In My R6E pressing the Switch BIOS button on MB do nothing, I only could Switch between BIOSs using BIOS Settings Screen (F2), why this button not working ?
    Is This Board Supporting This CPU 9980XE ? what shall I do Next ? BTW the CPU was Sealed in BOX and Brand NEW, can it be defected from Manufacturer and Sealed in BOX?
    Please Help!!!!!
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 7980XE Custom IHS @ 4.6Ghz 1.23v
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1AORUS GeForce RTX™ 2080 Ti XTREME WATERFORCE WB 11G
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 512gb
    Storage #2Samsung 850 Evo 1TB x 2
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master Vanguard Series 1000W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    CODE 00 is ether corrupt bios or dead CPU sadly I would recommend taking your XE back, on a side note the 9xxx and even 7xxx are only 6gen architecture so you wasted your time waiting, the 9980XE is just a higher binned 7980XE.
    ayman_abm PC Specs
    OS Windows 10 Pro
    Sep 2012
    32
    Quote Originally Posted by LiveOrDie View Post
    if it was a corrupted BIOS it wouldn't run the Older CPU (7900x) in the shop right? so you thought its a DEAD CPU ?
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    Quote Originally Posted by ayman_abm View Post
    Yes if it boots with another CPU and the boards bios has been updated the CPU is dead.
    ayman_abm PC Specs
    OS Windows 10 Pro
    Sep 2012
    32
    I Found that in some angels you can find Chines letters written on the CPU, is that NORMAL ??
    ROG Guru: White Belt Array
    Dec 2011
    11
    99
    With all of the Intel CPU's I've owned over the years I don't ever remember there being Chinese characters written on them.
    I have read somewhere about some Chinese manufacturers taking cheap processors and hacking them to identify them as something else. There were also reports of fake processors sold on Amazon.
    This could simply be a case of a dead genuine CPU though. Who knows.
  7. #7
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    Never seen that it could be a fake that CPU doesn't look new, it could be re-stemmed xeon or something what does the bottom side look like?
  8. #8
    ROG Guru: Yellow Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega
    ProcessorIntel® Core™ i9-9980XE CPU @ 3.00GHz
    Memory (part number)Corsair LPX Vengeance DDR4 DRAM 2666MHz 128 GB
    Graphics Card #1Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB
    Storage #2Samsung 970 Pro 1 TB
    CPU CoolerROG Ryujin 360
    CaseThermaltake View 71 TG
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot)
    Mar 2019
    178
    Dears,
    Please Help!!!!!
    You have a Rampage VI Extreme, right?! The Asus product list says your board supports and I quote: "Intel Socket 2066 for
    Core™ i9 X-Series Processors 79xx, 78xx Series." The Rampage VI Extreme Omega is the board that supports the whole family of 2066 processors.
    Problem solved.
  9. #9
    Dec 2011
    11
    99
    Quote Originally Posted by Super Gnome View Post
    Problem solved.
    The R6E does support the 9980XE with the latest BIOS.
  10. #10
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    Problem solved.
    OMFG please do not post here if you have no knowledge or understanding about BIOS's LMAO
Tags for this Thread
