Results 1 to 3 of 3
    New ROGer Array
    Mar 2019
    1
    Help Ascertaining WIFI Problem
    Hello all,
    I've recently upgraded my motherboard to a ROG B450-F gaming motherboard. After doing so, I've noticed wildly inconsistent internet speeds and random ping spikes. I only get these inconsistencies on my PC with this motherboard, any other phone or computer in my household does not get this. I've also tried not one, not two, but *three* different network cards and I get the same result. Is there a possibility that there is something wrong with this motherboard? I believe I mentioned this earlier, but this only started with this motherboard which leads me to think it is the cause, though I am unsure why.
    Also, before you ask, due to location difficulties using ethernet directly is an impossibility for me.
    Thanks for any help or advice the community can give, and I apologize if this is in the wrong location!
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,887
    Make sure you have the latest drivers for everything from the ASUS website. In one rare circumstance Windows update installed a version of the Intel Management Engine that killed my wifi speeds and made my system unstable. Getting the latest version from the manufacturer's website fixed it.
    It might also be the location of your PC is a wifi deadzone. Are you able to rotate the machine or move it closer to a doorway, at least temporarily?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: White Belt Array TimeLion724's Avatar
    Jan 2018
    113
    It could be your routers setting also, usually when there is a lot of people with Wifi in your neighborhood, the wifi channels begin to conflict because most people's routers are using the same channel, and that causes the problems you are experiencing...
    " The speed of the fallen one does not change..."
    GUIDE TO FIXING BSOD ERRORS
