Rampage VI Extreme with Rog Front Base + RYUGIN 240
Gushy
Hello,
i recently upgrade my pc with new motherboard ROG RAMPAGE VI EXTREME new liquid cooler ROG RYUJIN 240 and ROG front Base
So my problem is this.
I see in motherboatd there is only one 9 pin USB 2.0 port, which i use for ROG RYUJIN 240, but now my ROG Front Base leave with no USB 2.0 port i can use to work.
Please tell me what i must do to make them both work ?
If i need extention or something i will buy.
Thank you in advanced
6 REPLIES 6
G75rog
You can use a USB 2 header splitter.
Gushy
Can you show me which one please ?
Thank you in advanced!
Gushy
Well USB 2 header splitter will not work becouse the ROG_EXT cable take the USB 2.0 port, which on my botherboard is only 1.
The ROG_Ext cable cannot be split in two..
80088
So please if someone had another idea please.
1mluer
Level 11
I don't see your motherboard on the compatible list
https://www.asus.com/us/Motherboard-Accessories/ROG_Front_Base/
go close to the bottom for listed motherboards.
All I see is
Intel X99
Rampage V Extreme
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Not the Rampage VI extreme
I am not sure how much weight this has but it's not on the list ?
I think everyone else was referencing this
https://www.amazon.com/NZXT-Internal-Controller-Black-AC-IUSBH-M1/dp/B01IFGFTJ2/ref=sr_1_1?crid=33X1...
or a similar product.
InWin 909 Silver RGB build
i9-10900k
ROG Maximus XII Apex
ROG Matrix 2080 ti
Gskill Trident Royal 4400 16g
Everything overclocked and love it.
ROG Awesomeness !!!!
Gushy
I have this in bottom. I have used Rog Front Base 2 month already and it worked perfect.
But the issue is that the USB 2.0 por for 9pin cabble is only 1 in the motherboard.
So i need to chose to use my RYUGIN or the ROG Front Base.
80089
That i have on my motherboard, but the issue is that the ROG front page EXT cable look like this, and there is no another usb 2.0 port.
80090
That is the reason i ask for help.
Or maybe that would work for me ?
80091
1mluer
Level 11
I would go with the nzxt and the like options that plug into your motherboard and provide passthrough from there. It's cleaner and it's powered if anything is using power from it.
i9-10900k
ROG Matrix 2080 ti
