Results 1 to 1 of 1
    New ROGer Array
    Apr 2019
    1
    A Guide on Using Foobar2000 for Listening Music with ASUS ROG Centurion
    Just received my ASUS ROG Centurion gaming headset and man, I didn't expect this coming!
    I mainly bought it to watch movies and playing some games, but then I discovered a new way to listen to music. In this guide I will explain how to properly set Foobar2K to listen music with ASUS ROG Centurion in 7.1 mode, using all of its drivers. It's time to push this beast to its limits!
    Requirements:
    Foobar2000 full installation
    Channel Mixer component for Foobar2K
    Graphic Equalizer component for Foobar2K
    Firmware MCU v2.2 and DSP v2.4 for ROG Centurion (downloadable from ASUS ROG forums)
    ASUS Sonic Studio software
    After installing the above-mentioned, go to Windows sound settings and set the volume to 100.
    Then open Sonic Studio and push all channel volumes to the max.
    Also turn off Bass Boost, Voice Clarity, Compressor and Reverb.
    Now open Foobar2K. Press Ctrl+P to open preferences. Drag the components' dll files to the window to install the components.
    After installing the components, go to the Output section and choose "DS : Speakers (ASUS ROG 7.1)" as the output device.
    Now go to Playback --> DSP Manager. Add Channel Mixer, Upmix to 7.1 and Graphic Equalizer to Active DSPs. Remember, the order is important (the upmixer must be below Channel Mixer).
    Now click on "..." in front of Channel Mixer. In General tab, select 6 channels and check them all.
    Set Stereoimage width to 1.00.
    Go to Upmix tab. Set the Mode to Copy.
    Set all volumes to 1.00.
    Go to Subwoofer tab and check Use subwoofer and Bass redirection.
    Select Subwoofer channel from the first list and set the volume to 1.50.
    Select Leave satellites intact from the second list and set the Frequency to 300. Click OK.
    Now click "..." in front of Graphic Equalizer. Uncheck Auto and set the volume to -6.0 dB (in order to prevent clipping in the subwoofer channel). Click OK.
    Now you can go to Sonic Studio and equalize the headphone as you wish. I personally use the followings:
    0, 0, -4.5, -6.0, -1.5, -1.5, -1.5, -6.0, 0, 0
    Enjoy your Centurion. I personally didn't expect this kind of performance from a gaming headset.
