Results 1 to 6 of 6
Thread: Lane allocation
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus R6EE Bios 0702
    Processori9 10900X @ 5.0 1.37V VCore
    Memory (part number)GSkill F4-4000C18Q2-64GTZR
    Graphics Card #1EVGA 2080 Ti
    Sound CardCreative SB AE7
    MonitorAsus ROG PG349Q
    Storage #1Intel 905p M.2 360G
    CPU CoolerEKWB Magnitude RGB and Quantum Kinetic D5
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Asus Strix Flare
    Mouse Asus ROG Gladius II Origin
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,209
    Lane allocation
    I’m considering a M11E with a 9900k but I wanted to know about lane allocation. If I use a sound card in the very top x1 slot with an x16 video card in PCIe slot 1, will the video card drop to x8 if I use only 1 m.2 in the dimm.2 slot? The manual suggests it would drop to x8 since there are only 16 lanes for the CPU. The first PCIe slot would share bandwidth with the dimm.2. Correct?
    ROG Guru: Yellow Belt Array Enderwiggin03 PC Specs
    MotherboardROG STRIX Z390-E Gaming
    ProcessorIntel Core i9 9900k @ 5.1Ghz on all 8 cores 1.355v
    Memory (part number)F4-4266C19D-16GTZR @ 4000Mhz CL16-17-17-35 1.45v
    Graphics Card #1EVGA RTX 2070 XC Ultra
    Sound CardCreative Sound Blaster X AE-5
    MonitorASUS VG248QE
    Storage #1Samsung 970 Evo 500GB m.2
    Storage #2Samsung 860 Evo 1TB SATA
    CPU CoolerEVGA CLC280 with 4x NF-A14 iPPC-3000 PWM (push/pull)fans
    CaseFractal Design R6
    Power SupplyEVGA G3 1000w
    Keyboard Logitech G513 Carbon
    Mouse Logitech G703
    Mouse Pad Logitech Poweplay
    OS Windows 10 Home x64
    Nov 2018
    145
    Quote Originally Posted by Hopper64 View Post
    GFX card goes off CPU lanes (top 2 x16 slots) the others are chipset lanes (not direct to CPU).
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,209
    But the dimm.2 slot goes through the CPU as well. I suspect it will force the PCIe slots to x8.
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,209
    I read this review which suggests 2 m.2 drives in the dimm.2 will decrease the PCIe slot to x8:
    *“However, since this board employs a DIMM.2 it is worth noting those are CPU lanes as well so if you populate two M.2 Drives in the DIMM.2 module your main slot will drop to x8.”
    So this means one drive will not decrease the PCIe slot to x8? I question whether one drive would.
    https://www.bjorn3d.com/2018/11/asus...reme-review/3/
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    I would guess yes it would, but I am not going to remove one drive from my DIMM.2 module on my Gene to verify
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,209
    Aw, come on, take one for the team.*
