Results 1 to 9 of 9
    ROG Member Array KaRMiG PC Specs
    KaRMiG PC Specs
    MotherboardAsus ROG Rampage VI Encore
    ProcessorIntel Core i-9 10980XE OC 5.2GHZ
    Memory (part number)G-Skill TridentZ RGB (PC4-4000 CL19)
    Graphics Card #1Nvidia GeForce RTX 2080TI Founder's Edition
    Graphics Card #2Nvidia GeForce RTX 2080TI Founder's Edition
    Sound CardCreative Sound Blaster Gaming AE-9
    MonitorLG C8 55" OLED - ASUS ROG swift 27"
    CPU CoolerCUSTOM WATERCOOLING EKWB
    CasePhanteks Enthoo Elite Black
    Power SupplyCorsair AX1600i
    Keyboard Roccat Vulkan 120 AIMO
    Mouse Logitech
    Headset ASTRO A50 GAMING HEADSET
    Headset/Speakers Vintage AlteC Lansing speakers AB-Type amp
    OS Windows 10 Pro 64-bit
    Network RouterNetGear Night Hawk
    KaRMiG's Avatar
    Nov 2018
    6
    Problem with ASUS RAMPAGE VI EXTREME OMEGA: cannot detect memory
    HI:
    i'M having issues with my memory kits.
    when I use the XMP 4000, many times the system does not boot and I see "code 80 system cannot detect memory" on the status screen.
    Memory is on the qualified vendor list: G.SKILL TRIDENT Z, DDR4, F4-4000C18Q2-64GTZR PC4-3200 CL 18-19-19-39
    Another annoying thing is that If I shut the PSU off, when I turn on the PC again, it shuts off for a second then turns on again.
    I'm NOT overclocking, as the memory capacity is 4000hz by default.
    can I get some help to stop this from happening, please?
    Thanks in advance.
Name:	WhatsApp Image 2019-04-26 at 9.38.45 PM.jpg
Name:	WhatsApp Image 2019-04-26 at 9.38.50 PM.jpg
    ROG Guru: Orange Belt Array
    Oct 2017
    151
    To get your memory stable I suggest throwing some extra voltage to the VCCSA and VCCIO. When I am OCing (even though your not, you are technically OCing the memory as far as the CPU is concerned) to get my XMP memory stable I have to do this. Also you could try manually setting the memory clock speed down one or two settings.
    As far as the double pump at cold startup get used to it, it is a common behavior of MBs.
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus M13EG Bios 1007
    Processori9 11900K @ 5.2 1.50 VCore
    Memory (part number)GSkill F4-3600C16D-32GTRS
    Graphics Card #1Asus 3090 Strix OC/Optimus Block
    Sound CardCreative SB X4
    MonitorAsus ROG XG349C
    Storage #1Samsung 980 Pro
    CPU CoolerQuantum Kinetic TBE 300 D5 with Quantum VTX 160
    Keyboard Asus ROG Claymore 2
    Mouse Asus ROG Gladius III
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,364
    I have added 0.9700V to my VCCSA and I’m more stable now. I also added a 9900X which I think may have a better IMC than the 9800 I was using. Bumping the VCCSA likely will be needed. You should list all your hardware for review. Mine has always shutdown immediately on cold boot and comes right back up.*
    KaRMiG PC Specs
    Mouse Logitech
    KaRMiG's Avatar
    Nov 2018
    6
    Thanks. where can I find those settings?
    I'm new to these motherboard settings.
    my actual config is this:
    Intel core i9 7980xe cpu
    64GB ram G.skill 18-19-19-39
    Asus Rog Rampage Extreme Om ega
    1TB WD Black SSD nvme
    2x Nvidia RTX 2080TI
    Sound Blaster X AE-5
    Corsair AX1600i PSU
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,364
    Scroll down below the XMP settings you listed above on the same page.
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,364
    Look for CPU system agent voltage. Here are some of my prior settings:
    *https://rog.asus.com/forum/showthrea...t-throw-stones
  7. #7
    ROG Enthusiast Array Deathscythes PC Specs
    MotherboardRampage VI Extreme Omega
    ProcessorIntel Core I9-7980XE @5GHz
    Memory (part number)Trident Z RGB @3800MHz CL14
    MonitorASUS ROG PG258Q
    CPU CoolerDirect Die EK Supremacy Edge
    Deathscythes's Avatar
    Apr 2019
    35
    Hello,
    Keep in mind that getting a kit that's on the QVL doesn't guarantee in any way that you are going to be able to run said kit at its advertised speed and timings.
    For such speed on x299 especially on Skylake X HCC it's very likely for you to be limited by your IMC rather than by the dimms themselves not to mention that you populate all the slots.
    In my recent experience with a 7980XE and tightly overclocked ram, I have found that b die or at least my kit was extremely sensitive to heat.
    My kit is stable at 1.5V 1.27 VCCIO 3800 CL14 CR1 when maintained under 40°C .
    Prior to identifying what my issue was I wasn't even able to run 3800 CL15 with CR2.
    The thing is under prime or HCI the 18 cores running at 5GHz completely soak the PCB with heat and the dimms were reaching 60°C making them completely unstable even with a mediocre overclock.
    All of this just to say that you should pay attention to the thermals of your dimms so that you don't run into the same issues that I did.
    I hope that helps =)
  8. #8
    Apr 2019
    35
    If you have issues with booting, I strongly suggest you enable the training options of your memory in the bios and disable fast boots.
    That did the trick for me to boot at 4300MHz (which was unstable)
  9. #9
    KaRMiG PC Specs
    Mouse Logitech
    KaRMiG's Avatar
    Nov 2018
    6
    Thanks, guys for all the help and fast reposes. I will change my settings with your recommended ones, and I will share the results.
    EDITED: Following your advice, looks like memory is no stable and is not failed.
    voltage adjusted and fast boot disabled.
    Thank you very much for your advice, guys.
    You are the best.
    Thank you
Tags for this Thread
