Results 1 to 4 of 4
    ROG Guru: White Belt Array
    Jan 2013
    12
    91
    M.2 Install to Rampage VI E - Omega HELP
    Hi Guys,
    Firstly I've just finished my new build with the Rampage VI Extreme Omega Motherboard.
    First power up was a success. But windows failed to install. BSOD.... Ended up having to disable the Wireless adapter.
    Anyhow my question is, I have installed 2 x NVME PCIE Drives to the Motherboard and 2 x NVME PCIE Drives to the Dimm.2. I've installed Windows 10 but I only see just the 1 Drive.
    I know Dimm.2 needs to be enabled via BIOS I'll have to check this again I thought it was already enabled.
    Any help and advise on this?
    Thanks.
    MB: ASUS Rampage V Extreme
    CPU: Intel Core i7 5960X Extreme Edition
    RAM: Dominator® Platinum Series 32GB (4 x 8GB) DDR4 DRAM 2800MHz
    PSU: Corsair AX1200i Digital ATX Modular
    GFX: 3 x EVGA GTX Titan Black Superclocked 6GB
    SSD: 2 x Samsung 850 Pro Series 512Gb SSD Raid 0
    HDD: 2 x WD4003FZEX WD Black 4TB Raid 0
    1234;
    2 x WD1000DHTZ WD VelociRaptor 1TB Raid 0
    MON: Dell Ultra Sharp 32 Ultra HD Monitor - UP3214Q
    CASE: Silverstone Temjin TJ11 Black with Window Case
    OS: Win7 x64bit
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus R6EO Bios 0702
    Processori9 9900X @ 4.9 1.28V VCore
    Memory (part number)GSkill F4-3600C16Q2-64GTZR
    Graphics Card #1EVGA 2080 Ti Kingpin
    Sound CardCreative SB AE7
    MonitorAsus ROG PG349Q
    Storage #1Intel 905p M.2 360G
    CPU CoolerEKWB Velocity RGB and Revo XRes 140 D5
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Asus Strix Flare
    Mouse Asus ROG Gladius II Origin
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    36
    2,035
    There’s a setting in the bios under advanced/onboard devices configuration which enables/disables the m.2. Are you running 3 video cards? That may cause a lane allocation issue.
    Jan 2013
    12
    91
    Quote Originally Posted by Hopper64 View Post
    Hi, no I'm just running single 2080 TI Sea Hawk at the moment.
    BIOS see's all the M.2 drives:
    But just not showing up in the OS.
    1234;
    OS: Win7 x64bit
    Jan 2013
    12
    91
    Got it sorted.
    Quote Originally Posted by Counteragent View Post
    Ok all good guys, got it sorted.
    Went into Disk Management n bang there they were.... Maybe it was a matter of installing a raid driver.
    1234;
    OS: Win7 x64bit
