Results 1 to 6 of 6
    ROG Enthusiast Array whiskey-foxtrot PC Specs
    MotherboardCrosshair VI Hero
    ProcessorAMD Ryzen 7 1800X
    Memory (part number)F4-3200C14Q-32GTZR
    Graphics Card #1RX480 CFX
    Graphics Card #2RX480 CFX
    Sound Cardon-board
    Monitor2 x Dell 32" 4k UP3216Q
    Storage #1960 EVO 2TB
    Storage #2Seagate IronWolf 10TB x 4
    CPU CoolerAlways EKWB loops - for everything!
    CaseThermaltake X71
    Power SupplyEVGA 1200 Plat P2
    Keyboard Logitech RGB G810 Orion Spectrum
    Mouse Logitech G Pro & Logitech G600
    Headset Logitech G35
    Mouse Pad Logitech G440
    Headset/Speakers Logitech G35 & Bose Lifestyle 525
    OS Windows 10 Pro / Debian
    Network RouterD-Link 890-L
    whiskey-foxtrot's Avatar
    Apr 2017
    25
    Zenith Extreme Alpha memory issues on 0405
    So I've had zero issues with my memory G.Skill 3200MHz CL16 since I got the board in late January; it still had the original BIOS 0204 and I haven't upgraded the BIOS to 0405 till today.
    Now I'm unable to switch higher than 2666; I tried going to the public posted one (0207) with the same issues.
    Does anyone have all 8 ram slots filled on the 0405 BIOS and still achieve 3200MHz? or does anyone know how to get a copy of the 0204 BIOS which worked fine for everything I do.
    https://i.imgur.com/AlePnib.jpg
    Sound Cardon-board
    CaseThermaltake X71
    Apr 2017
    25
    Well, got it working finally. After specifically entering in the mem voltages for both channels it booted up just fine. Didn't have to do that on the original BIOS, but I'm back at 3200MHz and everything's running stable.
    Jan 2019
    60
    If you are getting 3200 on all sticks you need to really test it for error with some software.. i cannot belive that value is even remote to stable.
    ROG Guru: Brown Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    Little mentioned fact is on Threadripper we have access to PMU Training aka IMC. This has helped me on ZEA.
    I recently swapped from ZE to ZEA, I used the same CPU/RAM as used on previous board. Initially I had good repeatable results in Kahru RAM Test / P95 v28.10b1 / P95 v29.4b8 (upto 1hr each test suite). Later as I did more testing I had some erratic fails. I adjusted PMU training parameters and gained repeatable test passes. I did mix of full cold POSTs, full POSTS and warm POSTs, Kahru RAM Test did not fail . The validation testing length using Kahru RAM test was ~18hrs.
    This is Imgur album link to screenies, order is first test at top, PMU settings last image.
    Link to settings txt below.
    https://pastebin.com/JvKufYQd
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    Jan 2019
    60
    Quote Originally Posted by gupsterg View Post
    how did u get txt format for settings ? I can paste this in overclock forums cause here nobody gives a **** anyway.. rog support is mostly dead.
    Sound Cardon-board
    CaseThermaltake X71
    Apr 2017
    25
    Quote Originally Posted by macmus View Post
    Oh it's been stable ever since in my daily workloads (heavy 3D Rendering jobs in Blender, C4D, AE, Maya) - but of course I ran various tests OCCT (18+ hours), memtest86 20+ passes, and the basic ones like Aida64Extreme 8+ hours.
    I stream (game and encode on this PC) as well - no issues.
