Results 1 to 7 of 7
    ROG Enthusiast Array fcsoares43's Avatar
    Aug 2018
    43
    Asus GL503GE voltage Battery 5,2 Volts
    Hi is that normal 5,2 Volts to charge the battery Thanks
    Hwmonitor results
    Aug 2018
    43
    Urgent Please
    Quote Originally Posted by fcsoares43 View Post
    Hwmonitor results
    it´s a gl503ge
    Aug 2018
    43
    Urgent Please
    Weel it looks like that is a new issue of our Gaming, Asus says is a dificulty .
    thanks
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    300
    7,449
    If it's charging and discharging normally then it's fine. Is there a problem?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Aug 2018
    43
    Quote Originally Posted by xeromist View Post
    Weel the others machines like mine in HWMonitor shows voltages plenty high like 15Volts, do you think tjis is normal???
    Thanks
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    300
    7,449
    Well, I'm not sure what HWMonitor is reading. If the voltage was way off your machine would not work. Charge controller voltage will vary a bit by state of charge with lithium batteries but not what you're indicating. Amperage varies more based on load.
    Also, battery packs are not monolithic. They have multiple cells in series and parallel which can be balanced. The controller manages them and not all cell and controller configurations are the same. So different controllers may report differently.
  7. #7
    Aug 2018
    43
    I have two familiar members with the same laptop and the information is exactly the same so is not an issue is like this thanks
    Regards
