Results 1 to 3 of 3
    ROG Member Array
    Jan 2019
    8
    Gl504gm - fan issues have returned
    Anyone having ongoing problems with their laptop's CPU fans(left side). I had the problem several months ago and it disappeared. However the problem came back. I'm not even stressing out the laptop at all, just doing web browsing. It is such a hassle that I can't bring this to work anymore if it makes such a loud sound that it becomes too embarrassing
    ROG Member Array
    Oct 2018
    6
    i am also suffering this same fan issue. If we put fan boost in silent mode then also left side fan is making loud noise while doing web browsing. Also in ROG gaming center the GPU show 1 MHz and temperature -32768 degree.
    ROG Member Array
    Jan 2019
    9
    Same issue
    Im having this exact same issue, left cooler sounds like a turbo fan even when idle and temps are around 30-31°C
