Rampage VI Extreme Omega NVME RAID
Ruskiz
Guys,
I'm looking forward on doing a RAID 0 with the NVMEs , which are the best options for this particular motherboard.
RAID 0 = 3 x Intel 760p using the VROC
OR
RAID 0 2x Samsung 970 PRO
Any advise will be greatly appreciated .
4 REPLIES 4
bogsha
I have 2 970 Pro in Software Raid 0, it is fast, but you will not really notice the speed.
I'm Looking to do a Raid 0 too...Just the Nomal one via chipset, not thru CPU lanes.
is that possible with R6E?
Yes I believe its possible... As others have said gains are not like they used to be with RAID 0s.
MB: ASUS Rampage V Extreme
CPU: Intel Core i7 5960X Extreme Edition
RAM: Dominator® Platinum Series 32GB (4 x 8GB) DDR4 DRAM 2800MHz
PSU: Corsair AX1200i Digital ATX Modular
GFX: 3 x EVGA GTX Titan Black Superclocked 6GB
SSD: 2 x Samsung 850 Pro Series 512Gb SSD Raid 0
HDD: 2 x WD4003FZEX WD Black 4TB Raid 0
1234;
2 x WD1000DHTZ WD VelociRaptor 1TB Raid 0
MON: Dell Ultra Sharp 32 Ultra HD Monitor - UP3214Q
CASE: Silverstone Temjin TJ11 Black with Window Case
OS: Win7 x64bit
Hello! You can use RAID 0 on the Asus Rog Rampage VI Extreme Omega platform.
tried on ssd SAMSUNG 970 EVO Plus NVME M.2 via DIMM.2, nothing came of it
RAID INTEL VROCSTANMOD activation key - it also did not help.
Pluses for this bought a 2x M.2 drive Intel 760p Series.
install WINDOWS 10 on the created RAID 0, but not quite
He is not visible.
https://ibb.co/Mf50PxW
https://ibb.co/gZyjfxv
https://ibb.co/zJGzx8Z
https://ibb.co/Zm9MyKS
https://ibb.co/Wzx9n32
https://ibb.co/vV0GY4n
https://ibb.co/SsQ30xh
https://ibb.co/Y75Q9Yc
https://ibb.co/27gWDZ2
https://ibb.co/Dgn7Xps
https://ibb.co/Z6KYC6K
