Fastest 32 / 64GB RAM Kit for Omega
Counteragent
Hi Guys,
Looking for recommendations for best 32 / 64 GB RAM Kit for the Omega Motherboard.
I currently run the F4-3200C14Q-32GTZR which I think is decent just looking for anything better.
Currently running an Intel Core i9 9900X.
Thanks.
MB: ASUS Rampage V Extreme
CPU: Intel Core i7 5960X Extreme Edition
RAM: Dominator® Platinum Series 32GB (4 x 8GB) DDR4 DRAM 2800MHz
PSU: Corsair AX1200i Digital ATX Modular
GFX: 3 x EVGA GTX Titan Black Superclocked 6GB
SSD: 2 x Samsung 850 Pro Series 512Gb SSD Raid 0
HDD: 2 x WD4003FZEX WD Black 4TB Raid 0
1234;
2 x WD1000DHTZ WD VelociRaptor 1TB Raid 0
MON: Dell Ultra Sharp 32 Ultra HD Monitor - UP3214Q
CASE: Silverstone Temjin TJ11 Black with Window Case
OS: Win7 x64bit
10 REPLIES 10
pndiode
Level 11
Check your motherboard QVL list for memory.
Depends on CAS Latency and frequency of RAM. And CPU
https://www.wepc.com/tips/ram-speed/
LiveOrDie
Level 11
At one time I was distressed!
80278
jpmboy
Counteragent wrote:
Hi Guys,
Thanks.
I know it's heresy, but I have been running two G.Skill 4x8GB 3600c16 kits on my Omega/9900X rig. 4000c16 was very easy, and a very stable 4200c17 took a bit of tweaking, but has been very reliable and issue free. the 4200c17 settings are in the attached pics. Yes, I have the kits at 1.5V vdimm, for about a month now.
80289
80290
JuSiZ1
Counteragent wrote:
Hi Guys,
Thanks.
I have same kit and can make +4000mhz on it. I think any "better" kit is waste of money.
Ruskiz
I currently have the GSKILL Royal Z 3200mhz CL14 (F4-3200C14Q-32GTRS) it's super fast!
The memory can get overclocked to 17-17-17-37 , 4000mhz @ 1.45V
You can always check and compare using Ram Latency Calculator to see what's the best option for you, Link Below:
https://notkyon.moe/ram-latency.htm
Hey,
I'm looking for some 32GB/64GB memory (G.Skill Trident Z RGB) for my X299 ROG Rampage Omega. I don't want to manually configure voltages and latency etc.. and will be happy with just using ASUS EZ Tuning Wizard to do basic OC for me. I have an Intel i9 9900X. This would be for 1440p high-end gaming.
What kits do you recommend?
Thanks,
Beau*
Beauzinga wrote:
Hey,
Thanks,
Beau*
According to some of the previous posts, I would go with a non rgb 3600CL16 kit, or even two kits, since they are working nicely on the Asus Omega.
For example:
F4-3600C16Q-32GTZKK
The 3200CL14 are traditionally a good option too. But I like to see some GSAT or HCI captures to completely believe it, like jpmboy's.
Asus x670e Hero, 7950x, TG 7000, Master 4090, 970 PRO, 860 EVO, Intel 750,
SN850, SN750, 840 Pro, 2xSkyhawk 4TB, Pioneer S12U
EVGA T2 1600, Silverstone TJ11, Custom LC, Acer Predator x35, Philips OLED
For example:
F4-3600C16Q-32GTZKK
Thanks for the reply!
Looking at the QVL list for this board and what resellers are currently selling, I went with F4-3466C16Q-32GTZR most of the other kits are sold out or don’t sell anymore. Hopefully this will do the job just fine.
