HwInfo64 shows VMS in red (=Disabled) on XI Extreme
Silverbullit
Howdy forum-mates,
I would deeply appreciate your knowledged guru skills on the following,
HwInfo64 shows VMS in red (=Disabled) on my new Asus Maximus Decimus XI Extreme (Bios 0905)
I presume this is Virtualization?
I would like your advice on the why's & how's here friends.
In fact your feedback would be deeply appreciated!
/Silverbullit
5 REPLIES 5
no1yak
Silverbullit wrote:
Howdy forum-mates,
/Silverbullit
You are correct , VMS is Virtualization and it is usually defaulted to disabled in the Bios. I personally leave it at default . I don't fully understand the use of this setting but, i'm sure someone will put us both in the picture.
Arrite, that calms me somewhat. Appreciate your feedback mate!
Sorry I did not reply quicker, had to RMA my XI Extreme as it amongst other things frooze on bootup and showed Code B4 load vga bios. (With every GPU I tried)
The new RMA motherboard spontaneously started showing same error code with completely different components/GPU's/Bios asf.
SirWaWa
mine is disabled as well
you check in windows 10 under task manager performance under the cpu tab
virtualization: disabled
Silverbullit
Yeah, you are correct, it seems it is dissed for everyone. I dunno if I should care aboot this feature or not?
1mluer
Level 11
VMS is disabled for everyone. I had to enable to run Virtual Box and VMware. it's a bios setting under advanced > CPU area It's just turning on Virtualization on your CPU.
InWin 909 Silver RGB build
i9-10900k
ROG Maximus XII Apex
ROG Matrix 2080 ti
Gskill Trident Royal 4400 16g
Everything overclocked and love it.
ROG Awesomeness !!!!
