Results 1 to 9 of 9
    ROG Enthusiast Array
    Jan 2019
    32
    Using Blue Tooth.
    Do I have to do anything to activate the blue tooth on the ROG Crosshair VII?
    I'm using a Pantech Renue P6030 phone temporarily tonight, and when I try connecting it to my PC via USB, Windows 10 says there are errors and it can't read the phone. It can read the SD card inside the phone, though.
    So I thought I would try using the Blue Tooth on the Renue phone instead. When I have it search for Blue Tooth devices, the phone can't detect my PC.
    The phone also can't detect my Canon printer, for what it's worth.
    The phone can connect to my car via Blue Tooth, so the Blue Tooth does work with something.
    The phone's USB port does seem a little messed up, as a cable doesn't fit nicely inside anymore. That wasn't the case in March, when I last had to use the phone for a night.
    I am able to connect via Blue Tooth from the PC to my printer. I'm just wondering if there's something else I can do to make this phone connect to the PC via Blue Tooth.
    Thanks.
    ROG Member Array Othello PC Specs
    Othello PC Specs
    MotherboardROG Crossfire VIII Hero
    ProcessorAMD Ryzen 9 3950X
    Memory (part number)G Skill F4-2933C14D-16GFX
    Graphics Card #1PowerColor Liquid Devil
    Graphics Card #2MSI Reference RX 5700 XT
    Sound CardOn MB
    Monitor2 ea. Samsung C27HG70QQNXZA
    Storage #1Samsung 970 EVO M2 1TB
    Storage #2GB 1TB SSD PCIe 4.0
    CPU CoolerCustom H2O using Optimus Foundation WB
    CaseCorsair Graphite Sersies 780T
    Power SupplySeasonic PRIME Platinum 1200W
    Keyboard Logitech G910
    Mouse Logitech G502 Hero
    Headset Logitech G635
    OS WIN10 Pro
    Feb 2019
    24
    As far as I know the MB does not have blue tooth capabilities. One version has wifi capabilities but not blue tooth.
    ROG Member Array
    Aug 2018
    11
    Wif mode has both capabilities, its a 2in1 module (WiFi + Bluetooth)
    Don't forget to install the provided antenna, it serves both WF and BT functionality.
    Jan 2019
    32
    Quote Originally Posted by Othello View Post
    It seems like it has blue tooth here:
    https://www.asus.com/us/Motherboards...pecifications/
    Bluetooth
    Bluetooth V4.2*4
    Quote Originally Posted by elbubi141180 View Post
    I have the antenna connected to my PC.
    Is there something I have to do if I want to make a Blue Tooth connection only from my desktop to this phone? This phone can only connect via Blue Tooth.
    Is there some setting somewhere or something I have to enable?
    I wish Windows 10 could read the phone when I connect to it via USB, but it keeps saying there's some errors.
    My Windows 7 PC did a little better, in that it recognized it if I connected it as a music player. But if I connected it as a mass storage device, then it also wouldn't read it.
    ROG Member Array
    Feb 2019
    14
    Quote Originally Posted by nuraman00 View Post
    Bluetooth
    Bluetooth V4.2*4
    under bios, i think there is an option to have the bluetooth disable but it should be enable by default, if not you might have faulty adapter like a lot of other people experience with this board. I rma my board because bluetooth wifi was unstable, will disappeared at random.
    Jan 2019
    32
    Quote Originally Posted by dandan1108 View Post
    Can you help with where the setting might be? I looked, but couldn't find anything relevant.
    The 2 issues I've had with this board are:
    * USB Type C port not working.
    * Blue Tooth not working.
    While I'm disappointed, I can't disassemble my PC for these things. Not worth that much amount of time and headache to do all of that.
    There wouldn't be any other way to get this fixed, would there be?
    Or is there some expert service where they could come to my house and fix it? I'd rather pay for that, then disassemble my PC.
  7. #7
    New ROGer Array RedSector73 PC Specs
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    40
    701
    Bluetooth
    Bluetooth V4.2*4
    It does not appear to have Bluetooth listed natively on the motherboard, does not even have Wi-Fi ?
    https://www.asus.com/Motherboards/RO...-HERO/gallery/
    What phone do you have because nearly all can connect with data cable ?
    Are you running Windows 7 on this - hope not ?
    Install the latest chipset drivers, assuming Windows 10 this should get you type c port working.
    https://www.amd.com/en/support/chips...ocket-am4/x470
  8. #8
    Jan 2019
    32
    Quote Originally Posted by RedSector73 View Post
    There are two models of the ROG Crosshair VII Hero. The one I linked to is the ROG CROSSHAIR VII HERO (WI-FI).
    It has a different link:
    https://www.asus.com/us/Motherboards...WI-FI/gallery/
    The one you linked to is the ROG Crosshair VII Hero.
    You can see the differences in the title too, after clicking on each link.
    Yes, mine has Wi Fi, I have used it before.
    I am on Windows 10.
    Thanks for the suggestion about installing the chipset drivers. I will try that and report back.
    Do you think this could get the Bluetooth working too?
    I didn't want the Bluetooth on my PC, for connecting to my phone. It was for external devices. Such as an AV Receiver; a camera; etc.
  9. #9
    Apr 2018
    40
    701
    Ok well download drivers here for the Wi-Fi & Bluetooth. This should get it going.
    https://www.asus.com/us/Motherboards...Desk_Download/
    select Windows 10 64 bit, then scroll down, download and install wireless & Bluetooth drivers.
    Another method (However, It is assuming Intel wireless Wi-fi / Bluetooth device, which my CH8 is)
    https://www.intel.com/content/www/us...assistant.html
    Dont use chipset driver from here, use the ones from AMD that I mentioned in the first previous post.
