Results 1 to 7 of 7
    ROG Member Array
    Oct 2013
    22
    Where can I purchase a new OEM battery for an Asus ROG G551JW???
    Can someone tell me where I can purchase a OEM battery for an Asus ROG G551JW? I purchased a battery fro Best Buy and is garbage. I called Asus and they told me to send my computer to them. They would not sell me a battery or tell me where I could purchase one. If I cannot purchase an OEM battery where and what battery would someone suggest?
    I will order from the US if I have to but I am in Canada and would prefer to get one from here if I could.
    Thank you in advance....
    ROG Enthusiast Array PhilG55vw's Avatar
    Oct 2012
    51
    Best luck I've had finding a vendor is do a Google on your battery's model number. You also might try Batteries+, not sure what they have currently.
    ROG Guru: Orange Belt Array
    Nov 2012
    55
    361
    Considering the age of your laptop, finding a fully functional battery from any site is going to be a crap shoot. I know several sites that have your needed battery but whether they can provide a good battery is not a given. And returning that battery for a replacement is troublesome.
    I could google for a Canada site, but that is what you should be doing. I can not recommend any battery source that would give you a fully functional battery for such an older model laptop. I normally source part numbers from the EU ASUS eStore. It doesn't even list your model.
    Good Luck
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    ROG Member Array
    Apr 2015
    22
    Cool G751JT very happy with new battery.
    For whats its worth I had all problems described above with my G751JT. For years I muddled through until battery pack went completely dead.
    I mustered up courage and bought a new battery off Amazon, found the utube video where the guys replaces battery on G751. I followed his steps and I now have a fresh battery and its like a new computer to me. No more worries about all the flashing lights.
    BTW I took the old battery pack apart to see if any of the 18561 batteries were good. I tested them all and though old and low on capacity they were all still good and probably were not the cause of failure. I attribute failure of this pack to the BMS, battery management system board that is in the pack, which controls the charging and balance of the 8 / 18650 LIPo batteries. These circuit boards are the weakness IMHO.
    ROG Member Array
    Apr 2015
    22
    New batteries available here though looks like they only ship to EU, UK etc.
    https://www.zandparts.com/en/Zand%20Parts-ZPCS-AUG751NB
    ROG Guru: White Belt Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.305 )
    MotherboardAsus motherboard
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB
    Graphics Card #1intel Hd 620 graphics 1GB DDR3
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec 294
    MonitorLcd monitor
    Storage #1Samsung 850 Evo 250GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch. Toshiba 1TB 2.5 inch
    CPU CoolerBuilt-in
    Casefrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek with ice sound
    OS Windows 10 64bit 1809 build no 17763.503
    Network RouterBsnl Wi-Fi modem with router
    Feb 2018
    118
    go to asus service center , get battery from there
  7. #7
    ROG Guru: Orange Belt Array navis995's Avatar
    Oct 2014
    50
    296
    ...ebay
    Asus Rog G750JZ
    Screen: 1920x1080 17.3'
    CPU: Intel® Core™ i7-4700HQ (3.0Ghz @ -70mV)
    GPU: GeForce GTX 880M 4GB (OC +70Mhz Core, +400Mhz Memory @ 1.000V)
    RAM: Samsung 32GB 1600MHz
    Storage #1: Samsung Evo 840 250GB
    Storage #2: Samsung Evo 850 500GB
    Storage #3: Seagate Barracuda 2TB
    Storage #4: Samsung Evo 128GB MicroSD
