Results 1 to 10 of 10
    ROG Guru: Yellow Belt Array kshafe777 PC Specs
    kshafe777 PC Specs
    MotherboardMaximus XI Formula
    Processor9900k
    Memory (part number)Trident Z RGB 64 GB 3600 speed
    Graphics Card #1EVGA RTX 2080Ti FTW3 OC
    Graphics Card #2EVGA RTX 2080Ti FTW3 OC
    MonitorASUS PG27UQ
    Storage #1Samsung 970 EVO Plus M.2 1TB
    Storage #2Samsung 970 EVO Plus M.2 1TB
    CPU CoolerHeatkiller nickel
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1200i
    Keyboard G.Skill KM780 RGB Cherry Mx
    Mouse Roccat LEADR
    Headset AKG K7XX
    Headset/Speakers Razer Nomo Pro
    OS 10 pro
    Network RouterRaptor
    kshafe777's Avatar
    Jan 2014
    179
    A fix for Aura Sync software
    I found this video walking through where the problem lies and how to fix it. * Enjoy 😊*
    *https://youtu.be/cqufDaj9CPs
    "Better to try and Fail, then not try at all" ~ Michael Jordan
    favorite YouTuber - KDSTech - https://www.youtube.com/channel/UCz0...iWiBx3v6CNR3yw
    New ROGer Array
    Feb 2019
    2
    Quote Originally Posted by kshafe777 View Post
    Thank you, I have succeeded.:d:d:d
    kshafe777 PC Specs
    Processor9900k
    MonitorASUS PG27UQ
    Mouse Roccat LEADR
    Headset AKG K7XX
    OS 10 pro
    kshafe777's Avatar
    Jan 2014
    179
    Quote Originally Posted by XiaoDing View Post
    that's awesome!!!!
    maybe an admin should sticky this thread???
    ROG Enthusiast Array DMAN999 PC Specs
    DMAN999 PC Specs
    MotherboardROG Strix B450-F Gaming
    ProcessorAMD Ryzen 5 2600 @ 4 GHz
    Memory (part number)G.SKILL TridentZ RGB F4-3200C16D-16GTZR
    Graphics Card #1MSI 1660 Ti Armor OC
    MonitorDell S2316M
    Storage #1Samsung 850 Evo 500 GB SSD
    Storage #2Crucial MX500 nvme m.2 SSD
    CPU CoolerArtic 33 Esports Edition
    CaseRosewill Challenger
    Power SupplyRosewill Photon 750
    Keyboard Cooler Master MK120 RGB
    Mouse Cooler Master MS120 RGB
    Mouse Pad SteelSeries QcK Gaming Surface
    OS Windows 10 x64
    DMAN999's Avatar
    Dec 2018
    42
    I did that exact same process a few times (and I didn't even know that video existed at the time) and it did NOT work for me.
    FYI
    I just did a clean install of Windows 10 as part of my yearly OS cleanup regimen and I re-installed AURA 1.07.57 and it is 100% working again.
    kshafe777 PC Specs
    Processor9900k
    MonitorASUS PG27UQ
    Mouse Roccat LEADR
    Headset AKG K7XX
    OS 10 pro
    kshafe777's Avatar
    Jan 2014
    179
    yeah. I actually did this on two different machines.. max xi extreme and max xi formula... worked perfectly.. I think the root cause is that Lighting Service folder.. or some file within it.
    ROG Member Array supertoast PC Specs
    supertoast PC Specs
    Laptop (Model)HP Spectre x360 15T Vega (2018)
    MotherboardASUS Maximus X Hero (WiFi)
    ProcessorIntel Core i7-8700k @4.8 GHz All Cores
    Memory (part number)G.Skill F4-3200C16D-16GVGB
    Graphics Card #1ASUS Strix GTX1080 8G Gaming (Non-OC)
    Monitor27" BenQ
    Storage #1Samsung 970 Pro 512GB NVMe SSD
    Storage #2More SSD, 2TB Spinner
    CPU CoolerCorsair H115i Pro
    CaseFractal Design Define R6
    Power SupplyCorsair TX850M
    OS Windows 10 Home x64
    Dec 2017
    7
    Finally, I found the right thread! Thank you for sharing.
    After unintalling and reinstalling several times, CMOS reset, disable/enable RGB in BIOS, all without luck, deleting the LightingService folder under Program Files (x86) and then re-installing AURA fixed it for me.
  7. #7
    Jan 2017
    38
    Does this fix the issue where AURA won’t control certain components, i.e. my video ASUS card?
    Thx. *
  8. #8
    Jan 2017
    38
    Quote Originally Posted by WowMags View Post
    Does this fix the issue where AURA won’t control certain components, i.e. my ASUS video card?
    Thx. *
    I’ll take that as a “no”?
  9. #9
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    12
    1,409
    sor the moment mine is running fine event on 1903. there are some things that i am taking notes to send so it can be fix. small stuff. In did, some board like a friend AMD x470 need some adjustment. I will try my best to take good notes and share.
    Learn, Play Enjoy!
  10. #10
    MrAgapiGC PC Specs
    Processor9900K
    CaseNzxt H700
    Mouse Asus Spartha
    MrAgapiGC's Avatar
    Nov 2011
    12
    1,409
    got a wall on x299-E checking now
    got it let me see if i can duplicate the error.
    but x299-E las version is not working got the 1.07.57 in and worki
    Learn, Play Enjoy!
