Results 1 to 2 of 2
    ROG Member Array MarcT PC Specs
    MarcT PC Specs
    MotherboardASUS ROG Strix X470-I Gaming
    ProcessorAMD Ryzen 2700X
    Memory (part number)2x 16 GB G.Skill TridentZ RGB F4-320016D-32GTZRX
    Graphics Card #1ASUS ROG Strix RTX 2080ti Gaming, 11 GB
    Sound Cardonboard
    Monitor31,5" LG 32GK850G-B G-Sync 2560x1440, 144 Hz
    Storage #1Intel 660P M.2 SSD 512 GB
    Storage #2Intel 660P M.2 SSD 2 TB
    CPU CoolerAMD Wraith Prism
    CaseThermaltake P1
    Power SupplyASUS ROG Thor 850 Watt
    Keyboard Logitech G410
    Mouse Logitech G305
    Headset Philips Fidelio X2HR/00 High Resolution Over-Ear Kopfhörer + V-MODA BoomPro Mikrofon
    Mouse Pad Logitech G840
    Headset/Speakers Teufel Motiv 5
    OS Windows 10 Home 64bit
    Network RouterFritz!Box 6590
    Accessory #1 Logitech G305
    Accessory #2 Thrustmaster HOTAS X +
    MarcT's Avatar
    May 2014
    6
    ROG Strix X470-I - Maximum Sound Level too low
    i love my ROG Strix X470-I Mainboard, but te max. Soundlevel (headset) is a little bit too low for my taste.
    I tested it with two different headsets (Sennheiser PC360, Philips Fidelio X2HR/00 with VMODA Boom pro Mic) at the rear and front audio port.
    All Soundsettings are on maximum (100%). I use the onboard sound in stereo.
    The sound quality is good an i can hear nearly everything, but in games like PUBG (where a higher volume is helpful to realize enemy steps) i need a bit more.
    On my old PC, with a Soundblaster ZxR, i could bring it to a much higher (painfull) level. Not healthy, i know, but sometimes neccessary. :-)
    Is it a limitation of the board or missed i some settings? Any experiences or hints?
    Thx for your help!
    Plays on: AMD Ryzen 2700X, ASUS ROG Strix X470-I Gaming, 2x 16 GB G.Skill TridentZ RGB F4-320016D-32GTZRX, 1x Intel 660P M.2 SSD 512 GB (System), 1x Intel 660P M.2 SSD 2 TB (Games), 1x ASUS ROG Strix RTX 2080ti Gaming 11 GB, 1x ASUS ROG Thor 850 Watt Netzteil
    Thermaltake P1 Case, Windows 10 home 64bit
    New ROGer Array Pulainguravoastr PC Specs
    MotherboardAsus strix x470-i
    ProcessorRyzen 2700x
    Memory (part number)g.skill 3200 cl 14
    Graphics Card #1Asus strix gtx 1080Ti
    MonitorAsus strix xg35vq
    Apr 2019
    2
    Same problem here! The sound is super low even at max...marketing!
