Results 1 to 5 of 5
    New ROGer Array
    Mar 2019
    2
    Help! How can i fix this broken ram slot clip
    See attached picture.
    Its not affecting usage, but just hits my OCD nerves alot!
    Please let me know if there is anything to replace the broken clip.
    Thank you!
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600
    Memory (part number)16GB DDR4
    Graphics Card #1GTX980
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,346
    Swap with a clip from a donor motherboard? You'd have to make sure it's a similar model to ensure it matches and fits. I wouldn't buy a whole board just for one clip, personally.
    Alternatively, you could take all clips off of the empty slots so the populated slots match and the empty slots match.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Mar 2019
    2
    Quote Originally Posted by xeromist View Post
    so the clip CAN be taken off? how?
    xeromist PC Specs
    ProcessorAMD 2600
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    294
    7,346
    I don't have your specific board so YMMV, grain of salt, etc. However on some boards the retention clips snap onto the slot and can be (relatively easily) popped off. I bought a used ASUS server board and half the clips were missing. I popped the rest off and moved them around; so it can be done on some ASUS boards.
    Make sure there is no power to the board and all memory is removed so you don't accidentally slip and damage anything. I would start with the broken clip since it's already broken. Move it to the open position and look at how it is attached. Many boards have a couple of plastic nubs that fit into holes on the slots and provide a rotation point. The clip may be removed by gently bending the clip open where it grabs the slot or gently tweaking it to the side. Either way, if you start to see the slot flexing I would stop before damaging the solder joints.
    Memory fits pretty snug so you don't even really need the retention clips for a stationary system. If you can't easily remove the clips I'd leave them be. Certainly not worth damaging something for this minor an issue. If you have to transport it you may want to remove that stick or at least check it when you reach your destination to make sure it hasn't come loose. Otherwise it will be fine just sitting there.
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,456
    That;s old type of ROG Motherboards.
    ASUS use same color as DIMM slot last 5 years for sure.
    I checked, last Rampage IV launched 2011 had such clips.
    And last Maximus 6 series had them as well, that's 2013 I think.
