Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    ROG Enthusiast Array
    Feb 2019
    28
    47
    Exclamation GL703GM laptop battery percentage increasing very slow
    Hello again.
    My ASUS ROG GL703GM, has been damaged after 3 months only. The RED power button and the WHITE bulb remain open (light). No display, no keyboards light, nothing.
    Send it to service to repair in warranty.
    After one week the laptop is back with the motherboard changed.
    Now, all is working fine, but the laptop battery percentage increasing very very low.
    Has been received with 25% percentage only and has been tested a while... Connected the power cord, the battery show connected, charging but very very slow.
    About 0.1% in many minutes.
    Discharged to 0% to charge again. The laptop, after 56-58 hours show me 70% battery percentage and still charging.
    What can I do?
    The OEM AC Power adapter is damaged after 3 months?
    The battery is damaged after 3 months?
    The new Motherboard is damaged?
    I have to try a new power cord, then a new AC Power adapter, the a new battery. There is no other sollution
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    45
    337
    I would say one or more battery cells are going bad or something wrong with the charging circuit. Definitely nothing to do with the AC adapter.
    Try resetting the EC chip. Turn it off, hold the power button until the LEDs flash, then power it on again.
    Feb 2019
    28
    47
    Quote Originally Posted by FULLMETALJACKET7 View Post
    I try many options. Nothing. Now is charged at 100% after 4 days... but there is another issue
    All games are jamming at every 2-3 seconds.
    Yesterday, my son test the GTA 5, the FIFA19 and all games are jamming at every 2-3 seconds.
    The GTA 5 benchmark show 180 FPS for 2-3 seconds, then 20 FPS for 1-2 seconds, and so on...
    Windows 10 is updated, NVIDIA GTX 1060 has the latest drivers.
    WTF?
    The AC POwer adapter is working fine with the battery disconnected.
    I run METRO EXODUS for 1 minutes. Not played, just I run for test and I go in all directions with the keyboard only. Then I exit.
    So the AC Power adaper is good and is working fine without the battery.
    Now I have to open the case again to disconnect the battery again to test some games.
    It's possible to jamming games if the battery is damaged ?
    I don't know which word to say in english for this... Interruption in games. Like a framedrops at very slow FPS for every 1-2 seconds at every 2-3 seconds or 1-2 seconds....
    I can't play the games at normal performance. Sometimes it looks like the Counter Strike is working properly. The interruption is very rare...
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,410
    It might be possible for a failing battery to cause this if it's causing the power mode to change. What happens if you just run games on battery without the AC adapter? It will perform worse but is it consistent or still speeding up and slowing down?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Feb 2019
    28
    47
    Quote Originally Posted by xeromist View Post
    I have to testing this. I'm not testing the games with the battery only. I'll do this today and I'll reply here
    With AC Power adapter and battery connected I test GTA 5 in NORMAL graphiccs mode (not HIGH or VERY HIGH), and resolution to 1600x900. Is working fine, but sometimes and very rare I have frame drops, but with the maximum enery power saver of the processor set it from 100% to 99% only. I the settings are to 100% I have many frame drops.
    With mininam resolution like 1366x768 is working fine, but who play this ?
    I have to open the case again to disconnect the battery and test the games with the AC POWER adapter only in full performance. I'll be back with a reply
    I don't want to belive that the laptop has issues because the a new motherboard has been changed
    Feb 2019
    28
    47
    Working fine with the battery connected only. There are no FRAMES DROPS in games if the laptop stay connected with the battery only.
    If the AC Power charger is connected, all games get FRAMES DROPS at every 1-2 seconds, then is working fine again for 1-2 seconds and so on...
    So the AC Power adapter is damaged. Has no power to charge the battery and the laptop.
    Today someone come to me with his AC Power adapter for GL703GM to test my laptop. If is working fine, then I have to change the AC adapter, else I have to test the games with the AC Power adapter connected, but without the battery connected.
    If the issue persist, then the new motherboard is damaged (changed in the warranty)
  7. #7
    Feb 2019
    28
    47
    I buy a new AC Power charger with 19.5 V, 11.8 A and the same issue. The battery of my laptop not charging. Original AC Power charger has 19.5V and 9.23A.
    The Windows show charging, but the percentage not increasing. The same... I have FRAMES DROPS in the games with the charger connected.
    If I disconnecting the AC POWER adapter I can play the games without FRAMES DROPS on the battery only. At good resolution and set to HIGH or VERY HIGH. Now I have battery percentage 46% only...
    Today I try do disconnecting the battery amd I try to play the games with the charger only to see if the FRAMES DROPS persisting...
    If is working fine with the charger only could be the battery? Right? Or if is not working fine with the AC Power charger only and the FRAMES DROPS persisting, the issue come from the new motherboard, changed in the warranty from the last 2 weeks ago...
    I must send it again to the service to change the motherboard again
    The laptop is working fine, Windows, memory, M2, SSD, external devices, no problems. Only FRAMES DROPS in the games with the AC charger connected only
    CONCLUSION: I get good performance in games running on battery only, but bad performance while the charger is connected.
  8. #8
    ROG Enthusiast Array fcsoares43's Avatar
    Aug 2018
    43
    Quote Originally Posted by GeoBRB View Post
    Well i think i have i little problem like you, please teel me your battry charge in hwmonitor or hwinfo how many Volts are accusing and what is your level wear of the batttery
    Regards
  9. #9
    ROG Guru: White Belt Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.305 )
    MotherboardAsus motherboard
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB
    Graphics Card #1intel Hd 620 graphics 1GB DDR3
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec 294
    MonitorLcd monitor
    Storage #1Samsung 850 Evo 250GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch. Toshiba 1TB 2.5 inch
    CPU CoolerBuilt-in
    Casefrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek with ice sound
    OS Windows 10 Insider Preview 64bit 1903build no 18950.1001
    Network RouterBsnl Wi-Fi modem with router
    Accessory #1 Dell Mouse
    Accessory #2 Laptop Cooling table with fan
    Accessory #3 Secureye Usb finger print scanner
    Feb 2018
    122
    type the following commands in cmd with admin rights
    powercfg.exe /ENERGY -output C:\energy-report19-05-2019.html /duration 120
    powercfg.exe /BATTERYREPORT -output C:\battery-report19-05-2019.html /duration 14
    results will be stored in C:\
    upload results in Online storage and share the link here
  10. #10
    Feb 2019
    28
    47
    Hello again.
    @raju2529 here is the link:
    https://www12.zippyshare.com/v/v15yDLAU/file.html
    Take a look here...
    The battery has been disconnected to test the motherboard with AC Power adapter only.
    The laptop still get FRAMES DROPS in all games.
    So the motherboard is damaged. Has been changed in the warranty from 10 days ago.
    I have to send it again to the service.
    Guys, the battery not charging from one week ago. The Windows show me charging but not chrging
    Belive me the new motherboard is damaged.
