Results 1 to 5 of 5
    New ROGer Array
    Feb 2019
    2
    Exclamation GL504GW panel overdrive is disable
    I am not able to enable Panel Overdrive in Armoury Crate
    In profile is enable but on home Page is always disabled, I was even trying to enable it from mobile app but without any success. Any suggestions?
    Asus Strix Scar II with RTX 2070
    I Was trying to reinstall all drivers etc.
    ROG Member Array Ramahi89 PC Specs
    Ramahi89 PC Specs
    Laptop (Model)ASUS ROG STRIX SCAR II GL504GW
    MotherboardASUSTeK - Coffee Lake HM370
    ProcessorIntel Core i7 8750H @2.20GHz
    Memory (part number)(16X2) 32 GB DDR4 DUAL CHANNEL
    Graphics Card #1NVIDIA GEFORCE RTX 2070
    Graphics Card #2Intel(R) UHD Graphics 630
    Sound CardRealtek(R) Audio
    Monitor144Hz 3ms
    Storage #1512GB PCIe Nvme SSD
    Storage #21TB Crucial MX500 3D NAND SATA 2.5 inch Internal SSD
    CPU CoolerN.A
    CaseN.A
    Power SupplyN.A
    Keyboard VELOCIFIRE TKL02 Mechanical Keyboard (Brown Switches)
    Mouse RAZER DEATHADDER CHROMA
    Mouse Pad HYPERX
    OS Windows 10 Home Edition 64-bit
    Network RouterNetgear NightHawk R6700 Dual Band
    Sep 2014
    6
    Exclamation Same problem with Overdrive not being recognized as activated (Not Highlighted)
    Hello,
    I have a similar problem now that appeared after the armoury crate update, i was notified to download the update from windows store and it stated as a beta software; however I'm not sure if its a beta or not to be honest...
    Anyways my problem appeared as a Panel Overdrive not highlighted (as if i didn't activate it) or set it to activate when i select a certain profile. the attachments will clarify my problem.
    Anyone or any ROG employees that can clarify why this is happening please do.
    I hope it gets fixed soon.
    ROG Guru: White Belt Array
    Jul 2013
    11
    88
    did you guys have the armoury crate service installed?
    New ROGer Array fcsoares43's Avatar
    Aug 2018
    42
    Quote Originally Posted by TX2000 View Post
    I have the same problem too
    New ROGer Array
    Feb 2019
    2
    Yes, I have services.
    rest of the functionality works fine
Tags for this Thread
