RAMPAGE VI OMEGA M.2_2 NVMe SSD Issue.
Beauzinga_1
Hello Community,
I have a Samsung 970 EVO 250GB NVMe M.2 (OS) installed in the M.2_1 (SOCKET3) that is working perfectly but my Samsung 970 EVO 2TB NVMe M.2 installed in M.2_2 (SOCKET3) isn't being detected in BIOS or Windows. None of the SATA ports on the motherboard are being use and I have 2x GTX 1080's in SLI*setup.
What have I missed here? Any help would be appreciated.
Thank,
Beau*
6 REPLIES 6
Beauzinga_1
I removed the Samsung 970 EVO 2TB NVMe out from M.2_2 SOCKET3 and put in the Samsung 970 EVO 250GB NVMe (OS). I have nothing in the M.2_1 SOCKET3 and the Samsung 970 EVO 250GB NVMe M.2 (OS) can't be seen by the BIOS. I also took one of my 1080's out too. I also have nothing in the U.2 port. *
Thanks,
Beau
It turned out to be a DOA unit and had it replaced.*
Got my replacement unit and still have the same issue. Surely I can't have two DOA units in a row. Has anyone else had this issue or am I doing something wrong here?
xarot
Level 11
Page 9 in the manual: The U.2 port and M.2_2 slot will be disabled when using a 28-lane CPU.
Main: i9-10980XE - Rampage VI Extreme Encore - 64 GB G.Skill Trident Z Royal 3600 CL16 - Strix RTX 3090 - Phanteks Enthoo Primo - Corsair AX1500i - Samsung 960 PRO 1 TB + Intel 600P 1TB - Water cooling
HTPC: i7-6950X - X99-M WS - 32 GB G.Skill RipjawsV DDR4-2400 - GTX1050TI - Bitfenix Pandora - Corsair AX860 - Intel 750 400 GB + Samsung 1 TB 850 EVO
All around: i9-7980XE - Rampage VI Extreme - 64 GB G.Skill 4000 CL18-19-19-39 - Strix RTX3090 - Phanteks P500A - Samsung 960 EVO 512 GB - Water cooling
Oh wow, how did I miss this!? Thank you for pointing that out.
Time to upgrade!
Thanks!*
ayman_abm
I have R6E board with latest BIOS update, 9980XE CPU, also I have recently bought the Following
Asus Hyper M.2 X16 PCIe 3.0 X4 Expansion Card V2
Intel VROC STD CPU HW RAID KEY 0/1/10 (VROCSTANMOD)
4x Samsung 970 EVO Plus - 1TB PCIe NVMe
2x Samsung 950 Pro - 512GB PCIe NVMe
The Problem I have that I can't Build a raid-0 Volumes in BIOS, in both DIMM2 and Hyper m.2 card v2
Things I tried:
in BIOS tried to let it take control from CPU and from PCH, both failed
also tried to make make VROC hyper m.2 and DATA hyper m.2 and last tried PCIE 4X and made it DIMM2.
what Shall I do ? anyone have this new CARD Hyper m.2 V2 ??
