Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,358
    Anyone running SLI?
    Good day to all ROGer's
    Some say SLI is dying, some say SLI is dead altogether, well i say it depends on the games you play.
    I haven't run SLI since the 600 series and it worked very good in the games that support it. True, all games don't support SLI but the ones that do, show a nice increase in performance.
    So, I started this thread for anyone who is running SLI of any gpu generation to post their performance in games, that goes for anyone with 2000 series gpu's which now uses NVLink.
    I'll start off with the first game I tested which was Destiny 2, performance and gameplay are excellent with SLI. There are texture issues at times but this is a problem with the recording.
    Come one, come all, I'd like to see SLI performance in the games you play.
    Frames Per Second in the upper right corner in green.
    ROG Guru: Green Belt Array Heini PC Specs
    Heini PC Specs
    MotherboardAsus SABERTOOTH Z170 MARK 1
    Processori7-6700K
    Memory (part number)G.SKILL TridentZ (2 x 16GB) F4-3000C14D
    Graphics Card #1Evga 2080Ti XC Ultra
    Sound CardAsus Essence STX II
    MonitorASUS MG279Q
    Storage #1Samsung 950 Pro 512GB
    CPU CoolerNoctua NH-D15
    CaseCooler Master HAF XB EVO
    Power SupplyEVGA SuperNOVA G3 1000W
    Keyboard Ducky Shine 6 (Brown Cherry MX)
    Mouse Secret (Ducky)
    Headset Sennheiser HD 580
    Mouse Pad EVGA TORQ
    Headset/Speakers Logitech Z906
    OS Win10 Pro 64
    Heini's Avatar
    Nov 2013
    50
    600
    Specs show you have both water cooled, good deal. Maybe I ought to build the AMD machine that I've been contemplating and put two Radeon VII cards in it .... We could race!
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,358
    Thank you Heini !
    Zen 3 and Navi coming soon, double check if Hitman supports crossfire.
    I got a water block and back plate for the 2nd Titan Xp but have not installed it yet, I'll install it when I build the new pc. I can only get a little at a time so it's gonna be a good while.
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,358
    Testing has come to hault as a stick of my ram died, will post more SLI results when I get a new kit.
    Heini PC Specs
    Processori7-6700K
    MonitorASUS MG279Q
    Mouse Pad EVGA TORQ
    OS Win10 Pro 64
    Heini's Avatar
    Nov 2013
    50
    600
    Sorry to "Arne" ... it isn't closed to me!
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,358
    Not sure what happened but somehow this thread got closed, until I get a new ram kit, here is Superpostion results with 8GB of ram.
Name:	superposition 430.64 sli.png
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,358
    I've been looking at some 16GB ram kits and debating myself what I should go with.
    I asked myself this question which I'm sure has been asked a million times, "Which is better for gaming, higher frequency or lower latency? " After researching you'll find you'll get both answers to this question and leaves you with your arms thrown up in the air.
    The most relevant thing I came across is, " higher frequency = more bandwidth which edges out latency." Price reflects this too, higher frequency = higher cost.
    Newegg Seems to have the best price for Trident Z at the moment, I feel my 7700k and Maximus IX Code are up to the challenge so I chose these.
  8. #8
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,358
    So the ram finally came today and I was anxious to to see if it could run at 4133MHz but sadly it cannot. I could boot at 4000MHz with 20-21-21-41-2T but I wasn't happy with that, lowering the frequency to 3952MHz let me tighten the timings to 16-16-16-35-1T which I'm much happier with and this looks like the best it can do.
    Click the pic to make it bigger.
  9. #9
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(3) SSD's - Samsung 960 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    45
    1,002
    I'm running Xfire, but haven't tested recently. I had a video card fail on me in the last couple months, so I bought another one on ebay. Haven't taken the time to put it in the system yet though. After I do I can re-test.
    Davemon50
  10. #10
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,358
    Cool Dave, yes I would like to see how Xfire is working for you, please post all you want.
    The above ram settings were too good to be true so after tuning it a bit I settled on 3600MHz 15-15-15-30-1N timings which I'm happy with.
    Now that I can test some more games, FAR CRY 5 plays well in SLI but DOES NOT max out the gpu's. I could enable V-Sync and keep locked at 60FPS which is fine for me but this would bother me more if I had a 4k 144Hz monitor. It's showing the cpu running at 4600MHz but it's just reading the multiplier of x46, the cpu is running at 5.2GHz as shown in HWinfo above.
    While SLI does work it's not working like it should, so to me Far Cry 5 is an SLI fail.
