Opinion temperatures I7 8700K delid to 5.2 - Maximus XI Extreme - Help
theotorm
Hi everyone
I wanted an opinion on the temperatures of my I7 8700K that I pushed to 5.2 ghz with voltage 1.376.
I state that I gave it a long time ago but I always kept it at 5.0 ghz and I decided to raise the frequency a little.
The CPU is cooled with a NZXT KRAKEN X62.
At the moment I have no screen to post but I will provide them in the next few days because now they are not the headquarters.
Here are my 5.2 temps measured with hwmonitor.
10 rounds IBT very high: 74-66-68-71-69-69
5 consecutive benchmarks with Intel Extreme Tuning Utility: 72-65-71-70-68-67
15 minutes of stress with AIDA64 Extreme: 75-70-74-73-74-71
what do you think? I ask you that with 5ghz they have always been excellent with the delid but now raising to 5.2 they have increased a lot.
In game instead after half an hour of Metro Exodus all ultra with rtx 2080ti, warmer core 60.
Did I make a good delid? can I rest assured even in the summer months?
I await your expert opinion and thank you very much.
tunc8686
İts sound good bro*
When i was using 8700k delid 5.3 ghz 1.400V 77C
İf you want you can try 5.3 bc your result pretty good *
tunc8686 wrote:
İts sound good bro*
to go to 5.3 I should go to 1.40v or more ... it would be a problem no?
