LiveDash 1.05.03 doesn't work
Hopper64
Level 15
Posted this in the software forum. For the R6EO just don't bother. It does not work at all.
https://rog.asus.com/forum/showthread.php?111060-LiveDash-1-05-03-doesn-t-work
MZ790A Bios 2002, GSkill F5-8000J3848H16GX2-TZRK, 13900KS, EKWB D5 TBE 300, Seasonic Prime TX-1600 ATX 3.0, Asus Strix 4090 w/ Optimus block, Phanteks Enthoo Elite, Asus Claymore 2, Asus Gladius 3, Asus XG349C, Samsung 990, Windows 11 Pro
1mluer
Level 11
A lot of the time you have to restart the lightingservice under the services panel and it all kicks back in or at least mine does. But yeah it is not correct yet. Mine take almost 5 minutes before livedash actually kicks in after restart and you can then run the livedash client. I usually know when it's running when I see my selected system stats and the light bar startup. Give it 5 minutes and then restart the lightingservice and give it up to 5 minutes. It usually works the 2nd time.
It runs until you shut down the machine then it's rinse and repeat. Try the lightingservice trick and see if it works for you. I would love to know. I have Ryujin 360 connected.
InWin 909 Silver RGB build
i9-10900k
ROG Maximus XII Apex
ROG Matrix 2080 ti
Gskill Trident Royal 4400 16g
Everything overclocked and love it.
ROG Awesomeness !!!!
Hopper64
Level 15
I reinstalled....version.02 and it came up. This is without restarting the service.*
SirWaWa
with this running is it allowing your cpu to downclock during idle?
it wasn't for me, I had to do a windows restore because the asus software is so invasive with the registry and the uninstall wasn't just enough
