Results 1 to 3 of 3
    ROG Member Array
    Sep 2015
    7
    Asus Maximus XI Hero (Wifi) - W_PUMP+ setting fault
    Hello
    I'm using Asus Maximus XI Hero - Wifi - Bios update to latest 0805. My custom loop using EK D5 - PWM, i connect to mobo with W_PUMP+.
    Btw i cant edit/change any value on Water pump control setting.
    ROG Member Array
    Sep 2015
    7
    Any help please ?
    ROG Member Array
    Feb 2019
    5
    Quote Originally Posted by YuchiRO View Post
    Any help please ?
    Try changing the Q Fan source setting to something other than CPU and see if you can edit it then. Might need to put it to manual or something else. I think when you put it to CPU it is just copying the CPU_Fan defaults or whatever you have set for CPU_Fan PWM settings.
    I'm not in the bios so not really sure, but I usually see the grayed out settings when one of the settings that is set above them has automatically adjusted it to a default profile.
