Results 1 to 4 of 4
    ROG Member Array
    Apr 2014
    13
    Used a Windows Pro Upgrade Serial and now my System is stuck to Enterprise edition.
    I used an official Windows Pro Upgrade serial that i bought from Amazon, the system erroneously switched to Windows Enterprise edition, and now not even a complete reset can change that. My Windows can't activate. How can I reset Windows to the original Registration Key?
    ROG Guru: Orange Belt Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.309SA )
    MotherboardAsus Builtin Motherboard X542UQ
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB DDR4
    Graphics Card #1intel Hd 620 graphics 1GB DDR3 DCH WHQL driver v29.20.100.9116
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5 DCH WHQL driver v27.21.14.6521
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec 294 WHQL driver v6.0.9071.1
    MonitorBuiltin Lcd monitor model BOE
    Storage #1Samsung 850 Evo 1000GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch 5400rpm and Seagate 2TB 2.5inch 5400rpm2.5 inch
    CPU CoolerBuilt-in
    CaseFrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Purchased Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek Builtin Speakers
    OS Windows 10 Enterprise 64bit v20H2 build no 19042.685
    Network RouterBsnl Wi-Fi modem with router
    Accessory #1 Dell Wired Mouse
    Accessory #2 Laptop Cooling table with fan
    Accessory #3 Secureye Usb finger print scanner added seperately for Windows Hello
    raju2529's Avatar
    Feb 2018
    9
    323
    That serial might belongs to enterprise.
    Enterprise edition is better than professional
    ROG Member Array
    Dec 2018
    8
    I'd get in touch with Microsoft. I don't think this has anything to do with ASUS. Perhaps MS can alter the license linked to your MS account.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,754
    Quote Originally Posted by raju2529 View Post
    Enterprise requires a licensing server on your network. Hence it is not appropriate for home users or even small businesses. OP got scammed.
    @Pretzel: You can try the link below. Unfortunately sometimes enterprise keys disable some autonomy of the systems even if you have administrative rights so removing the key may not work. In that case it might be easiest to wipe the drive and reinstall from scratch.
    https://www.howtogeek.com/124286/how...-sell-your-pc/
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
Tags for this Thread
