Results 1 to 2 of 2
    ROG Guru: White Belt Array AgentHunk's Avatar
    Jul 2018
    85
    Exclamation Issue with OBS streaming live on youtube
    below are my obs settings I have been tweaking around with it and some viewers have been complaining that it is poor quality and blurry and somewhat skippy here and there making it unwatchable....
    I have seen some plays being a freeze for a few seconds and then continue.this happens frequently.
    I have changed the bicubic to bilinear....since I made this post.
    at the very bottom are youtube livestreams to show my problems.I am still trying to figure out how to fix this.
    I just had a Clock_watchdog_timeout BSOD while doing obs streaming to youtube.
    keep in mind I was using the h264/avc encoder option.
    I tried earlier the cpu option and tried veryfast,superfast and ultrafast and it seemed to have skip more than the gpu render option...I do not know how to go about finding the best optimized setting for my Laptop...Both CPU and GPU is powerful.
    I read that this model from amd was rated for perfect livestreaming online...
    what I dont know is was it rated for wired ethernet connections?
    or wifi connections?wireless?
    with that being said,is 400mbps good?wifi?wireless?
    now,troubleshooting has come back clean,viruses clean,drivers up to date,ram diagnostics are good.
    what could be the issue????why is the livestream skipping and hicupping????
Name:	Attila capture 2.jpg
    https://www.youtube.com/watch?v=Qjq5RDmRZK0
    https://www.youtube.com/watch?v=vj9e_FKga7E
    https://www.youtube.com/watch?v=_ILCJa2nK5g
    https://www.youtube.com/watch?v=VJHS...ature=youtu.be
    Jul 2018
    85
    OBS z264 settings issue
    today I tried again using OBS and this is the results
    Attila Legendary WRE 436-441 A.D. Fourth Chapter - YouTube
    6 hours only got save of 55 minutes worth...
    using these settings in OBS
    no matter which encoder I use it seems I cannot enjoy making a decent livestream.
