Results 1 to 2 of 2
    ROG Member Array
    Jan 2019
    8
    Restore to original sound settings on GL504
    Hi All, been tinkering with the sound settings on my GL504GM, the one with the fluctuating sound output and accidentally uninstalled in device manager Audio Device and Sound Devices. When i installed the latest ROG update all the sounds from my laptop have disappeared! Already tried running windows update and sound troubleshooter but so far nothing has solved the issue.
    ROG Enthusiast Array fcsoares43's Avatar
    Aug 2018
    42
    Quote Originally Posted by anon852 View Post
    Try to go back with an early restore point, or desinstall all you have in your notebook that as to be with your sound, then reinstall all firdt drivers of the unit then the rest and that must do the trick
    Regards
