Results 1 to 6 of 6
    ROG Guru: White Belt Array
    Jan 2013
    12
    92
    PCIE 4.0 Will it come to ROG VI Omega
    So I've heard certain other MB vendors will release support for PCIE 4.0 to their current range of MBs.
    Do you think its possible Asus may do the same with the VI Extreme Omega?
    MB: ASUS Rampage V Extreme
    CPU: Intel Core i7 5960X Extreme Edition
    RAM: Dominator® Platinum Series 32GB (4 x 8GB) DDR4 DRAM 2800MHz
    PSU: Corsair AX1200i Digital ATX Modular
    GFX: 3 x EVGA GTX Titan Black Superclocked 6GB
    SSD: 2 x Samsung 850 Pro Series 512Gb SSD Raid 0
    HDD: 2 x WD4003FZEX WD Black 4TB Raid 0
    1234;
    2 x WD1000DHTZ WD VelociRaptor 1TB Raid 0
    MON: Dell Ultra Sharp 32 Ultra HD Monitor - UP3214Q
    CASE: Silverstone Temjin TJ11 Black with Window Case
    OS: Win7 x64bit
    ROG Enthusiast Array
    Mar 2012
    51
    Quote Originally Posted by Counteragent View Post
    Barring electrical differences that could make this technically impossible, given ASUS' modus operandi of providing a reasonable level of software/hardware updates to their products for 2-3 months post-launch and then effectively forgetting that they ever existed, I'm going to go with the chance of this occurring being around 0.
    ROG Enthusiast Array Shanester PC Specs
    Shanester PC Specs
    MotherboardROG MAXIMUS EXTREME / ROG RAMPAGE VI EXTREME OMEGA
    Processori9-9900K / i9-7900X
    Shanester's Avatar
    Aug 2013
    18
    59
    Here, here Mike.
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 10980XE 4.6Ghz 1.12v WC
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1EVGA RTX 3080 XC3 ULTRA EK WB/BP
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 1TB
    Storage #2Samsung 860 Evo 1TB x 3
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master V 1300W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    No it won't not with X299G/X499 around the corner to replace the current boards, the omega has a slim chance of supporting the next gen CPU coming out.
    ROG Guru: Orange Belt Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.309SA )
    MotherboardAsus Builtin Motherboard X542UQ
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB DDR4
    Graphics Card #1intel HD 620 graphics 1GB DDR3 DCH WHQL driver v.30.100.9667
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5 DCH WHQL driver v30.0.14.7076
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec ALC294 WHQL driver v6.0.9151.1
    MonitorBuiltin Lcd monitor model BOE
    Storage #1Samsung 850 Evo 1000GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch 5400rpm and Seagate 2TB 2.5inch 5400rpm2.5 inch
    CPU CoolerBuilt-in
    CaseFrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Purchased Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek Builtin Speakers
    OS Windows 10 Enterprise 64bit v21H1 build no 19043.1055
    Network RouterNextVision ONU Fiber Modem
    Accessory #1 G40 Wired Gaming Mouse
    Accessory #2 Laptop Cooling table with fan
    Accessory #3 Secureye Usb finger print scanner added seperately for Windows Hello
    raju2529's Avatar
    Feb 2018
    9
    361
    adding support of pcle 4.0needed compatible and supported chipset. On chipset design we can able to add support
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Quote Originally Posted by raju2529 View Post
    That would be AMD not intel chipsets.
