Nvidia Hot Fix Driver 430.97
toronto699
Hotfix Driver Version 430.97
https://nvidia.custhelp.com/app/answers/detail/a_id/4808
•Code 43 error when installing driver 430.64 on Windows 10 May 2019 Update system with Intel Sandy Bridge CPU
raju2529
Thanks for the informnation sir .
Today downloaded sam Hotfix Driver Version 430.97 and i successfully installed on top of 430.86 without problems on ASUS VIVOBOOK 15 R542UQ-DM153 wth bios x542UQ.307 on windows 10 1903 64bit buildno 18362.116
All installed games are working fine
Intel i5 7200U_ Nvidia 940MX _Windows_11_Enterprise_64bit_22H2_buildno_22621.754
Nate152
Thank you toronto699
There's nothing in the hotfix for me, I'm going to skip this one.
raju2529 - Good to hear all is working well.
When installing a new Nvidia driver, you can do a Custom (Advanced) Install. After the license agreement click Custom (Advanced), here you can check the box that says perform a clean installation and it will remove the previous driver.
I do this instead of installing on top of the old driver.
I could not able to install uisng setup.exe , instead i install usng .inf file through device manager .
I install only DCH whql signed drivers from intel and Nvidia directly.
I dont check in asus website
