Results 1 to 5 of 5
    New ROGer Array
    Apr 2019
    4
    Asus G752 VSK i7 7820HK GTX 1070 - Screen Problems, High Temp.
    Hello
    I have Asus G752 VSK i7 7820HK GTX 1070 - Screen Problems, High Temp. What's happening?? How to fix it?? Replace the paste or is the graphics problem ???
    Temp cpu 80-91C
    Temp gpu 88-91C
    Video is here look https://www.youtube.com/watch?v=x4DjQ6u4qps
    ROG Guru: Orange Belt Array navis995's Avatar
    Oct 2014
    50
    300
    The artifact you're getting is probably not due to the temperature although I cannot be too sure but I personally never had artifacting because of high temperature and I had my GPU reach 95°C.
    Hopefully its because of software issuse and not hardware.
    Try to remove current nvidia drivers and install latest ones or older version.
    Remove then with Display Driver Uninstaller.
    The GPU temperatures will decrease if you repaste the laptop and clean it. I recommend a good thermal compound like latest noctua paste or something similar.
    Asus Rog G750JZ
    Screen: 1920x1080 17.3'
    CPU: Intel® Core™ i7-4700HQ (3.0Ghz @ -70mV)
    GPU: GeForce GTX 880M 4GB (OC +70Mhz Core, +400Mhz Memory @ 1.000V)
    RAM: Samsung 32GB 1600MHz
    Storage #1: Samsung Evo 840 250GB
    Storage #2: Samsung Evo 850 500GB
    Storage #3: Seagate Barracuda 2TB
    Storage #4: Samsung Evo 128GB MicroSD
    New ROGer Array
    Apr 2019
    4
    Holly f****. I got this bios 305 xD
    [IMG=https://zapodaj.net/images/4730652643f3f.jpg]link[/IMG]
    ROG Guru: White Belt Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.305 )
    MotherboardAsus motherboard
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB
    Graphics Card #1intel Hd 620 graphics 1GB DDR3
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec 294
    MonitorLcd monitor
    Storage #1Samsung 850 Evo 250GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch. Toshiba 1TB 2.5 inch
    CPU CoolerBuilt-in
    Casefrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek with ice sound
    OS Windows 10 64bit 1809 build no 17763.503
    Network RouterBsnl Wi-Fi modem with router
    Feb 2018
    118
    if new bios update firmware is available means then install through system firmware under device manager
    ROG Member Array
    Dec 2018
    11
    Like you, I also get the windows update notification to update my bios; something new, the truth, at 305.
    About the temperature it would be good to make a change of pasta, as advised above, and then do tests or explain to the subject that.
    I stopped playing Battlefield V, because it reached 95 ° + in less than 30 min. Before I played more than 3 hours and all good, it's weird.
    Asus: G752VS-K
