Need help with group policy update settings!
Thomas_extreme_
Hello, I need help configuring the group policy, always automatically restart at the scheduled time. I set the policy to enabled and I did net get a restart timer, and after 15 minutes pc did not restart nothing happened! Please help!!
1mluer
Level 11
What OS and user is assigned?
might want to use something like this in a .bat file:
The boards wouldn't let me write the code so I added it to a zip file as a batch file.
You would need to set this up in task scheduler
InWin 909 Silver RGB build
i9-10900k
ROG Maximus XII Apex
ROG Matrix 2080 ti
Gskill Trident Royal 4400 16g
Everything overclocked and love it.
ROG Awesomeness !!!!
I only have one user account and it is an admin account, the OS build is Windows 10 Pro 1903 1863.145
Can you also please make a .bat file to automatically check for updates and, if there are updates download and install them, then auto reboot (if possible after a few minutes, if not immediate restart is fine) Sorry for not asking earlier!
Thanks for your help in advance!
raju2529
after configuring group policy, you must add to Windows registry.
to do this type below command in cmd and press enter.
GPUPDATE /FORCE
Restart the Windows
Intel i5 7200U_ Nvidia 940MX _Windows_11_Enterprise_64bit_22H2_buildno_22621.754
