Results 1 to 6 of 6
    ROG Enthusiast Array
    Nov 2015
    40
    Temperature and overclocking aid I7 8700K Delid - HELP
    Hi everyone I wanted help on the overclocking of my 8700K delid + Maximus XI Extreme + KRAKEN X62. I have already verified that at 5.2 ghz we get stable with 1.376v. Unfortunately in my house there are already 27 degrees and the temperatures have gone up a lot (even 78 degrees with cinebench and 80 with IBT). VI place the settings of the 5.2 ghz bios, what can I change? Are the temperatures for a delid cpu too high? I ask you for a hand because I'm afraid of doing damage.
    continue below because it no longer made me upload images.
    Nov 2015
    40
    What can I improve to lower temperatures?
    here is a test with cinebench:
    and a game hour with Metro Exodus:
    The kraken pump speed is set to maximum and the fans are around 80% with a custom curve.
    Would you please help me fix lóverclock and tell me if the temperatures for a delid CPU are good or risk something? Thanks a lot!
    ROG Guru: White Belt Array HisEvilness PC Specs
    MotherboardASUS ROG Maximus Hero XI
    ProcessorIntel i7 8086k
    Memory (part number)32gb G.Skill TrridentZ RGB
    Graphics Card #1ASUS ROG 1080ti
    MonitorAcer Predator 27Inch/Iiyama G-Master GE2488HS-B2/ProLite E2474HDS
    Storage #1Samsung 960 EVO
    Storage #2Samsung 860 EVO x 2
    CPU CoolerCorsair 150i Pro
    CaseLian-Li Dynamic
    Power SupplyRMx 850
    Keyboard Roccat Vulcan 120 AIMO
    Mouse Roccat Kone AIMO
    Headset Sennheiser 58X
    OS Win 10 Pro 64
    Network RouterASUS RT-N18U
    HisEvilness's Avatar
    May 2017
    80
    Well since you are stable change: The CPU VCCIO Voltage and CPU System Agent Voltage could help with thermals.
    This guide I have written with an 8086k and those are my settings.
    https://www.hisevilness.com/articles...k-on-z390.html
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    76
    889
    Quote Originally Posted by HisEvilness View Post
    Your temps look right for the speed and voltage you are running under full load. I like the idea above of trying to lower your SA and VC voltages. Those tend to default too high. Might be some temp savings there. If you could notch down vcore even .005 and still run 5.2 it might be worth it. 1.37v is on the high end of safe voltage and really pushes the push the temps.
    Nov 2015
    40
    Quote Originally Posted by mdzcpa View Post
    But are they also good temperatures for a cpu delid or should they be lower?
    Nov 2015
    40
