Hi guys. I'm having a problem with the RGB 2 header on my Maximus XI Hero.
Like the title says, it displays wrong colors even though it showed the right colors during calibration and it used to work months ago before Aura software stopped working. Ive recently installed and uninstalled the aura software about 15 times just to get the software to work. Now that it works, this happened with header 2. Header 1 works just fine.
So the best example is that it shows orange when I set the color to white (255, 255, 255) and i get the same result no matter what RGB product i plug into it. Can someone please tell me whats going on?
EDIT: does anyone know if there is a way to test AURA sync using parted magic or some other mounted OS? I want to check if this is a software issue or hardware without reinstalling windows.
