Results 1 to 8 of 8
    ROG Guru: White Belt Array Zeroed85 PC Specs
    Zeroed85 PC Specs
    MotherboardAsus Maximus X Hero
    Processor8700K 4.9Ghz
    Memory (part number)Dominator Platinum 2x8GB 3200Mhz
    Graphics Card #1EVGA GTX 1080 Ti FTW3
    Sound CardSoundBlaster X AE-5
    MonitorAsus ROG PG348Q 34"
    CPU CoolerCorsair H110i
    CaseCorsair Obsidian 450D
    Power SupplySeasonic X-750 KM3
    Keyboard Logitech G710+
    Mouse Corsair Sabre
    OS Win 10 64 1709
    Jun 2017
    99
    X-Hero VRM temps?
    What's a normal VRM idle temp for the Maximus X Hero? Mine's sitting at 35C but I thought that it usually sat closer to the CPU idle temps?
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    13
    1,492
    Quote Originally Posted by Zeroed85 View Post
    temps for those are normal. do no worry about it.
    Learn, Play Enjoy!
    ROG Guru: Yellow Belt Array bass junkie xl PC Specs
    MotherboardAsus Rog X Hero Z-370 ( Wifi ) bios -2102
    Processori7-8700k @ 5.1 @ 1.34v @ manual vcore , De Lid + rockit cool copper ihs
    Memory (part number)G.Skill Trident Z RGB 16 GB 3000 Mhz cl-14 @ 4000 Mhz cl-17-19-19-39 @1.4v 1.21v vccio/vcssa
    Graphics Card #1Msi Gtx 1080 TI FE @ 1911 mhz @ 0.975v Curve - Driver 431.36
    Sound CardMotherboard Realtec , Driver 87.46
    MonitorAsus PG279Q , 27 inch 165 HZ , 1440p G-Sync
    Storage #1Intel 600P , 512gb m.2 nvme ssd
    Storage #2Kingston Hyper X furry 240gb ssd
    CPU CoolerThermalright true black 120 + 2 x 120mm push pull ( pump died rma )
    CaseThermaltake View 71 full Glass
    Power SupplyThermaltake Grand 750w RGB Platnuim
    Keyboard Logictec G510s
    Mouse Logictec G700s Wireless
    Headset Razer Kraken 7.1 chroma
    Mouse Pad Asus Sheeth Large
    Headset/Speakers Logitech z-5300 THX 5.1
    OS Windows 10-1809 x64 Pro
    bass junkie xl's Avatar
    Oct 2017
    18
    242
    how are you seeing vrm temps ? i have asus x hero z-370 wifi and in adia 64 i dont see anything to do with vrm
    ROG Enthusiast Array kens30 PC Specs
    kens30 PC Specs
    MotherboardAsus ROG Maximus X Code
    ProcessorCore i7 8700K 4.7avx 1.210v non-delid
    Memory (part number)G.Skill Trident Z RGB F4-3200C14D-32GTZR
    Graphics Card #1Asus ROG STRIX-GTX1070-8G-GAMING
    Sound CardSound Blaster Z + Onboard
    MonitorSamsung 32inch 1080p
    Storage #1Samsung 970 pro nvme 500gb
    Storage #2Samsung 960 evo nvme 250gb 850 pro 128gb x2 + WD 8tb
    CPU CoolerCorsair H110i gt
    CaseCorsair Graphite 780T
    Power SupplyCorsair AX860 Platinum
    Keyboard Corsair K70 RGB LUX
    Mouse Logitech G pro
    OS Windows 10 pro 1903
    Accessory #1 Microsoft Xbox One Controller
    kens30's Avatar
    Jan 2018
    47
    69
    Quote Originally Posted by bass junkie xl View Post
    On release day the first few batches of the Maximus X Hero had a vrm sensor, then it got removed on later boards.
    You can check using HWiNFO64 under the Asus EC section, VRM temps are monitored there.
    If you don't see VRM listed then your board does not have a sensor.
    Zeroed85 PC Specs
    Mouse Corsair Sabre
    OS Win 10 64 1709
    Jun 2017
    99
    That is what I've been told as well. Guess I was lucky to get one from the early batches. @bass junkie xl, I run a delidded 8700K also and the VRM rarely breaks 50C under sustained load. The VRM's are very good on this board, you have nothing to worry about.
    Oct 2017
    18
    242
    yeah i heard about how good the vrms are on these boards , i have 2 x 120 mm
    fans as intake blowing down on the vrm and ram so that helps to .dang i wish i had one maybe its miss named ? here is a ss of my info 64
Name:	hardware info 64.png
    i dont see ?
  7. #7
    ROG Guru: White Belt Array Carlyle2020 PC Specs
    MotherboardAsus Maximus XI APEX w/o vrm heatsink
    Processor8086K/@5.0/1.26
    Memory (part number)Corsair LPX 4000 CL19@17.17.37/360/2T/1.375
    Graphics Card #1OOO RTX 2080 Ti FTW3 ULTRA
    Graphics Card #2GTX 1060
    Sound CardOOO Xonar STX modified
    Monitor21: 9 LG 34 inch / flat
    Storage #11TB 960evo
    Storage #22TB 970evo plus
    CPU CoolerNoctua NH-D15
    CaseSilverstone FT2 +200 bucks of sounddampening
    Power SupplySeasonic Prime Titanium 1000W
    Keyboard Cherry KC 1000 / OOO CORSAIR K63 + lapboard
    Mouse MX Master 2S
    Headset Sennheiser PC360 + Philips X2HR
    Headset/Speakers klipsch 4.1 pc speaker /cooling modified
    OS Win 10 64bit
    Network Routeryeah right...
    Accessory #1 Silverstone EBA01 headphone stand / black
    Accessory #2 radio Keyfob to turn on and off from Garage
    Accessory #3 Adata USB3.1 512Mb SSD @480Mb ul/dl
    Mar 2018
    17
    91
    Some look like this:
Name:	Anmerkung 2019-07-28 184852.jpg
  8. #8
    Zeroed85 PC Specs
    Mouse Corsair Sabre
    OS Win 10 64 1709
    Jun 2017
    99
    i dont see ?
    Yeah looks like it's not there, it's usually above PCH. You can try looking in HWinFO under hidden items. You may be able to set a 10K thermal sensor wire up near the VRM but I'm not sure how accurate it would be. Does anyone know where exactly the VRM temp sensor is located?
