Results 1 to 1 of 1
    ROG Member Array nday76's Avatar
    Feb 2011
    13
    21
    Bypassing Battery Check during Bios Update?
    I have taken out and thrown away about to explode battery safely last year and I have no plans to ever getting a new battery.
    I noticed that there is a 310 bios update as windows updater automatically downloaded.
    However due to not having a battery inside, it won't allow me to update the bios. (fair enough)
    Now my system constantly boots into the EZ FLASH 3 Utility whenever I restart my computer since my windows 10 is trying to proceed the firmware update.
    I have disabled the auto firmware update from the control panel - system - advanced setting so I no longer have a problem.
    But here is my real question.
    How do i bypass the battery check on EZ Flash 3 Utility?
    I seartched google for hours and some mentioned that typing "risky" should work but it clearly didn't.
