Results 1 to 3 of 3
    ROG Guru: White Belt Array
    Jun 2017
    30
    98
    kabylake pci express root port #10 - a2b1 problem: URGENT!
    Hi, I'm sorry for the urgenty but I have a lot of problems with my PC (blue screen) and I don't know if the problem is "kabylake pci express root port #10 - a2b1" driver. I atach the pic of Device management. I tried to install it even manually choosing from my PC driver but I get error.
    How can I solve it please?
    THANKS
    I have: i9 7940X, Prime X299-Deluxe and GTX 1080Ti
    I installed the latest versions of everything and I did the latest Windows 10 update, that very eavy update but I have always that problem.
    I have a lot of problems with Edius 9 and blue screens.
    ROG Guru: White Belt Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.305 )
    MotherboardAsus motherboard
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB
    Graphics Card #1intel Hd 620 graphics 1GB DDR3
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec 294
    MonitorLcd monitor
    Storage #1Samsung 850 Evo 250GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch. Toshiba 1TB 2.5 inch
    CPU CoolerBuilt-in
    Casefrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek with ice sound
    OS Windows 10 64bit 1809 build no 17763.503
    Network RouterBsnl Wi-Fi modem with router
    Feb 2018
    118
    Reinstall intel latest chiset driver 10.1.1.45 from this website
    https://www.necacom.net/index.php/in...10-1-1-45-whql
    or from
    https://downloadcenter.intel.com/download/28768?v=t
    Moreover i seen screenshot , you installed incorrect and modded driver , actually kabylake name wont be displayed device manager
    then restart the windows
    Jun 2017
    30
    98
    Hey, thanks a lot for your precious info. But why are you telling me I have installed a wrong chiset driver? I downloaded it from Asus Prime X299-Deluxe web site.
    But I will install that you suggested me but I don't know what I have to do precisely to install it. But how can I do precisely plese? There isn't a Setup. Thanks
