Results 1 to 1 of 1
    ROG Guru: White Belt Array AgentHunk's Avatar
    Jul 2018
    85
    GL702ZC Fan boost Gaming Center
    I have noticed the fans not updating to the adjustment of manually sliding the fan settings from any % of speed..it just doesnt do it until I restart or max it all the way out.Is there a way to see if it can be fixed?I do not see the fan to max as acceptable...I do want the transition form 0-50% whenever I choose to do so.
    help....
