Yup, even when "not overclocking" clock speeds are set and vary. I'm also a (very recent X) R5E user, I regularly used to get boot issues, usually CPU over voltage, or overclocking failed errors, followed by a regular ritual bios self destruction! that said once it was "up" it was rock solid, even at 2.5 ghz on all cores.
As above I'd recommend choosing XMP, setting the correct RAM speed, check the recommend RAM voltage for your RAM try the latest bios if you are not already.
Are you on the latest intel chipset drivers and firmware?
Gotterdammerung: Rampage V Extreme | Intel I7-5930K | 32GB Corsair Dominator 2666 | EVGA GTX 980 SC x3
Kingston HyperX Predator 480GB | Corsair Neutron XT 960GB | Corsair AX1200 | Corsair 900D | EK RVE Monoblock | EK 980 GTX Blocks
GOOSE: STRIX Z390I Gaming | Intel i9-9900KF | 32GB Vengeance RGB 3200 | STRIX Vega 64 | Samsung 970 EVO Plus 1TB x2
Corsair SF 750 | Phanteks Evolv Shift X | EK Z390I Monoblock | EK Strix Vega 64 GPU Block
