RVE: Two rear USB 2.0 ports - can they be used as normal ports?
Aelius
On the RVE, there are two USB 2.0 slots at the back which it says are for BIOS Flashback and ROG Connect functionality. But can these ports also be used as ordinary USB 2.0 ports (e.g., for a mouse and keyboard)? I can't seem to find information anywhere about this.
CMDRZOD
Yes they work fine as normal USB 2.0 ports. I've used them in the past for things like KB/M and USB memory sticks. I keep them unused most of the time as there are many 3.0 ports to use.
You know you can just plug something in and see if it works.
