Results 1 to 6 of 6
    ROG Guru: Yellow Belt Array Zammin PC Specs
    Zammin PC Specs
    MotherboardASUS ROG Maximus XI Formula
    ProcessorIntel 9900K (Conductonaut Applied)
    Memory (part number)G Skill 3200Mhz Trident Z RGB 32GB 3200Mhz CL16
    Graphics Card #1RTX 2080Ti FE
    MonitorAcer Predator XB271HU 165Hz
    Storage #1Samsung 970 EVO 2TB M.2 NVME SSD
    Storage #2Samsung 860 EVO 1TB SSD
    CPU CoolerEKWB Velocity RGB
    CaseLian Li PC-011 Dynamic
    Power SupplyCorsair RM1000i
    Keyboard Corsair K95 Platinum RGB
    Mouse Steel Series Rival 600
    Headset Astro A50 (Gen 2)
    Mouse Pad ASUS ROG Scabbard
    Headset/Speakers JBL LSR305 Mk II
    OS Windows 10 Pro 64bit
    Zammin's Avatar
    Mar 2018
    13
    233
    Maximus XI Formula OLED Burn-In
    Hi everyone
    Just a warning to owners of this motherboard or any other ASUS LiveDash product that uses an OLED display, if you leave it on a hardware monitor or any other setting where there is static text, over time it will cause burn-in. I knew this was an issue with larger color OLED displays like TVs for example, but I hadn't realised that really small, basic, black and white OLED displays like this are affected as well.
    I realised today when I finally had a go at uploading my own animated GIF to display on the LiveDash and I can still see the words "CPU Voltage" and the outline of the numbers below as a dark outline on top of the animation. I had been using the CPU voltage readout for around 6 months prior to this. When the system is turned off it runs the standard "FORMULA" animation.
    I find this very annoying and yet another problem with this expensive motherboard. I tried googling the issue and nothing came up specific to ASUS LiveDash displays. So I thought I should post a warning for any owners of LiveDash equipped motherboards and AIOs.
    If anyone form ASUS is reading this it wouldn't hurt to put a warning in either the manual or the LiveDash software stating that static text and images can lead to burn in over time.
    ROG Enthusiast Array SentineL_VDXi PC Specs
    Laptop (Model)Dell Precision M7510
    MotherboardMaximus X Formula
    ProcessorIntel i7 8086K @5Ghz
    Memory (part number)Corsair Domi. Plat. 4x8GB (CMD16GX4M2B3200C16)
    Graphics Card #1EVGA 2080 FTW3 Elite Gaming
    Sound CardSupreme FX S1220a
    MonitorDell S2409W
    Storage #1Samsung 970 Pro 512GB
    Storage #22x256GB SSD RAID0
    CPU CoolerCorsair H150i Pro
    CaseCorsair Crystal 570X Mirror Black
    Power SupplyCorsair AX1200i
    Mouse Cyborg R.A.T. Pro X
    Headset Corsair VOID RGB
    Mouse Pad Razer Destructor 2
    Headset/Speakers Edifier R451
    OS Windows 10 Pro x64
    Network RouterASUS RT-AC88U
    Accessory #1 QNAP TS-251+
    Jul 2012
    68
    Thanks for the Info! Didn't think about that
    ASUS Products: Maximus X Formula - RT-AC87U/AC88U
    ROG Guru: White Belt Array
    Aug 2013
    83
    Agreed, My on the Rampage Extreme has the same issue. It is such a shame, Mine has dimed as well, so I just leave it off and use it only for post codes
    Jul 2018
    28
    Any type of OLED display will have this issue, i don't know why they use them with things that display static images
    ROG Junior Member Array
    Feb 2014
    2
    Quote Originally Posted by BroPhilip View Post
    How do you turn it off and only for POST codes?*
    Sep 2013
    49
    103
    IN THE BIOS you can configurate it. "Integrated periphals"
    That said, you can set iut up in Armoury to display as many as 6 values. This way it will change constantly and not bur the OLED
Tags for this Thread
