Livedash help
Tomy1990
Hello,
Why i can't disable livedash oled motherboard screen?
I trying in livedash settings, but when i press off and ok nothing happens, and when i go in settings again it's marked ON
Anyone have some solution i would be grateful
Re
Tomy1990 wrote:
Hello,
you can try this: go into your Livedash folder there must be a Setting file open it with the Editor (Admin) change the number to Zero ( i think the Option was named OLED = 1) save the file and start Livedash again*
Tried, didn't help, it's still on
