Results 1 to 6 of 6
    ROG Member Array
    May 2015
    9900kf 50/47 1.2v max temp 67 no delided, plus gskill 5000 mhz
    conclusions for 9900kf
    better temperature. no need to delid.
    better imc than 9900k
    my system
    9900kf 50/47 no delid. silicone TF8 with ek velocity cpu block and custom loop.
    maximus xi apex
    gskill royal 4600mhz oc to 5000 mhz
    ROG Enthusiast Array
    Aug 2014
    46
    59
    It's not the fact that the iGPU is disabled.
    It's the new stepping. Notice the "R0"?
    The 9900K's with iGPU will also get that stepping.
    ROG Guru: Yellow Belt Array ninezerofive PC Specs
    MotherboardMaximus XI Apex
    Processori7-9700K @ 5.2
    Memory (part number)Trident Z Royal 4000 / 2x8GB @ C17
    Graphics Card #1ROG Strix 1070 OC
    Storage #1Corsair MP510 960 GB
    Storage #2Seagate 3TB
    CPU CoolerROG Ryuo 240
    Power SupplyROG THOR 850W
    Keyboard ROG Claymore
    Mouse ROG Pugio
    ninezerofive's Avatar
    Nov 2018
    18
    194
    Temps are good, push it some more.
    ROG Guru: Yellow Belt Array bass junkie xl PC Specs
    MotherboardAsus Rog X Hero Z-370 ( Wifi ) bios -2102
    Processori7-8700k @ 5.1 @ 1.34v @ manual vcore , De Lid + rockit cool copper ihs
    Memory (part number)G.Skill Trident Z RGB 16 GB 3000 Mhz cl-14 @ 4000 Mhz cl-17-19-19-39 @1.4v 1.21v vccio/vcssa
    Graphics Card #1Msi Gtx 1080 TI FE @ 1911 mhz @ 0.975v Curve - Driver 431.36
    Sound CardMotherboard Realtec , Driver 87.46
    MonitorAsus PG279Q , 27 inch 165 HZ , 1440p G-Sync
    Storage #1Intel 600P , 512gb m.2 nvme ssd
    Storage #2Kingston Hyper X furry 240gb ssd
    CPU CoolerThermalright true black 120 + 2 x 120mm push pull ( pump died rma )
    CaseThermaltake View 71 full Glass
    Power SupplyThermaltake Grand 750w RGB Platnuim
    Keyboard Logictec G510s
    Mouse Logictec G700s Wireless
    Headset Razer Kraken 7.1 chroma
    Mouse Pad Asus Sheeth Large
    Headset/Speakers Logitech z-5300 THX 5.1
    OS Windows 10-1809 x64 Pro
    bass junkie xl's Avatar
    Oct 2017
    18
    240
    is the 9900kf currently avalible ? is it a lot better then the 9900k ? or should i wait for the 9900 ks 5 ghz out of the box and hope for low volts ? whats your guys opinion ?
    im on a 8700k @ 5.1 ghz and 4000 mhz cl-17 ram on a asus x hero am i missing out ?
    ROG Member Array
    May 2015
    Quote Originally Posted by bass junkie xl View Post
    KF is a lot better than 9900k. Temperature is about 10 degrees decrease.
    I'm not sure about temp whether it benefits from removing igpu or improve production quality .
    If you're not in hurry, wait for KS results first.
    IF you need it now go for KF. Because everyone will run at 5.0 ghz all core same as KS.
    ps.
    latest update ddr4 5360 mhz dual channel
    Oct 2017
    18
    240
    Quote Originally Posted by Pun_VI View Post
    ps.
    wowzers man !!! look at that mem and cache benchmark 70 + k and under 35 ns @ 5300 mhz
    1.5 v on cpu a little high but we are over clockers once they start to degrade we sell them and upgrade nice over clocks man
    i bet arma 3 would see a massive fps boost from 5300 mzh ram specialy cl-18 !! could you do a fps benchmark with these settings ?
    cpu @ 5 ghz and ram @ 3200 cl-14 1440p resultion no msaa
    vs
    cpu @ 5.3 ram @ 5300 mhz 1440p msaa off
    test some fps games and show use the fps min / avg / max with that ram oc ?
    making sure gpu usage is not 100% pegged before the test to see actual gains ?
